Hey everyone. I’m having a problem trying to figure out how to activate my 2 step off of 2 micro switches that I bought from quarter max. I want to wire it into the first gear linkage and the clutch pedal so that when the clutch is pushed down and it’s in 1st gear the 2 step is activated. It’s in a 69 charger and the transmission is a Gforce G101A. Just wondering if anyone has a wiring diagram they could post. I’m not the biggest fan of wiring. Thanks
Do you have a long shifter with the slider blocks? If you do mound the microspwith the contact the shifter block in first. If you have a non block style shifter used two side cover bolts to mount a microswitch bracket the is activated by the shift lever tab.
For the clutch I used the clutch pedal bumper stop hole for the ckutch micro but it eventually beat the switch to death a few times so I switched to a roller lever style from mcmaster.
As Gus said the need to be wired in series. I usually switch electronic stuff on the ground side if I have a choice these days.
