Axle shaft ID #2948809
07/30/21 12:12 PM
07/30/21 12:12 PM
God's Country Maryland
GODSCOUNTRY340 Offline OP
I got these axles many years ago, forgot what they go to. They're Mopar 4.5" bolt circle, 31 spline, 31 1/8" length from back of flange and are made for retaining clip. Anyone know if they're Dana 60 or 9 1/4" rear or whatever? Only number stamped in them is A1003. Thanx.
8FA7C623-4907-41A9-8BA9-E36995B808CD.jpegF3C513E8-4A5A-4338-915D-F782F356A0BC.jpeg091DFC00-BA37-4ED0-A4A9-C46255B1FEC9.jpegD6923C29-54E7-4C59-B017-E4E8A306D7C5.jpeg
Re: Axle shaft ID [Re: GODSCOUNTRY340] #2948859
07/30/21 02:41 PM
07/30/21 02:41 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I don't know for positive but I think those are Ford axles... They used the 4.5 spacing and those are C clip axles and I don't know if Mopar ever had 31 spline axles but Ford did..
Again I'm no expert but I've done a lot of looking lately since I just broke an axle last week...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Axle shaft ID [Re: Sledge_57] #2951538
08/08/21 05:54 AM
08/08/21 05:54 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Agree, look like ford axles to me, 31 spline tells the tale !
Re: Axle shaft ID [Re: Mcode69] #2951585
08/08/21 09:49 AM
08/08/21 09:49 AM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
could be 9 1/4 as, i think 9 1/4 also had 31 spline axle count. the reason that i say that is cause i looked at trying to find a 31 spline ford unit to see if the axles from 9 1/4 would fit so i could narrow a 9 1/4 housing and use ford axles.
Re: Axle shaft ID [Re: trw1982] #2951655
08/08/21 12:49 PM
08/08/21 12:49 PM
iagree scope up twocents
Re: Axle shaft ID [Re: trw1982] #2951669
08/08/21 01:29 PM
08/08/21 01:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Both the Ford and 9 1/4" are 31-spline but the Ford has a 90° spline angle and, I believe, the Mopar is 60°....might also be a different diameter. shruggy
Re: Axle shaft ID [Re: John_Kunkel] #2951684
08/08/21 02:32 PM
08/08/21 02:32 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
thank you john. i have tried to find that info as to the difference. i now know. also my dad has asked you before and i think you said no politely, hahahaha, but please write a book on the trans stuff you used to have and all the other knowledge you have. it would be flying off the shelf, especially all the trans info you posses. PLEASE DO IT. trw1982
Re: Axle shaft ID [Re: trw1982] #2952028
08/09/21 12:07 PM
08/09/21 12:07 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Does the 9 1/4 use C clips? Those look like C clip axles.... Never had a 9 1/4 so I have no clue there...
Doug
Re: Axle shaft ID [Re: Sledge_57] #2952048
08/09/21 01:50 PM
08/09/21 01:50 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Yes, 9-1/4 axles use C-Clips to hold them in.
Re: Axle shaft ID [Re: SNK-EYZ] #2952228
08/09/21 09:27 PM
08/09/21 09:27 PM
Don't Ford & Mopar have a different size center hole for the brake drums. If they do, anyone know the different measurements?
Re: Axle shaft ID [Re: GODSCOUNTRY340] #2952302
08/10/21 03:10 AM
08/10/21 03:10 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
A quick online search came up with
Quote
Chrysler: 2-13/16"
Ford: 2-3/4" (for the ones with a center hole that almost fits on a Chrysler, but not quite)
For the folks who are fond of the French units, that translates to:
Chrysler: 71.4375 mm
Ford: 69.85 mm
Re: Axle shaft ID [Re: SNK-EYZ] #2952402
08/10/21 11:23 AM
08/10/21 11:23 AM
moparx Online content
moparx  Online Content
from a few years of junkyard ownership [1872-1986] the ford axle register was 2.740-745 while the wheel center hole is 2.750 -2.765.
the chrysler hub register is 2.800-2.805, the wheel hole is 2.810-2.825.
i have measured these things countless times over the years, and these numbers are for bare, non rusted components. even surface rust will give different results, so measure carefully. rusty stuff will go together, but be a somewhat of a "beach" getting apart. kind of like beating on a tire/wheel assembly or a rear brake drum. we all know the drill for these. biggrin
hope this helps.
beer
Re: Axle shaft ID [Re: moparx] #2952775
08/11/21 11:44 AM
08/11/21 11:44 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Good Info . drive Thank you Bob . wrench ronnie
Re: Axle shaft ID [Re: 1969ronnie] #2953015
08/11/21 10:27 PM
08/11/21 10:27 PM
Just measured, 2 13/16". Must be for Mopar 9 1/4" rear. Thanks for all the help.
Re: Axle shaft ID [Re: GODSCOUNTRY340] #2953116
08/12/21 12:11 PM
08/12/21 12:11 PM
2 13/16 = 2.8125, so well into tolerance. you are good to go. up
beer
