Page 1 of 3 1 2 3
8.99 @ 3100lbs? #2952059
08/09/21 02:13 PM
08/09/21 02:13 PM
MN
JERICOGTX Offline OP
MN
If you were attempting to go 8.99 in a 3100lb car, how would you do it NA? What kind of power would it take? Gear set?
69 GTX 68 Road Runner
Re: 8.99 @ 3100lbs? [Re: JERICOGTX] #2952060
08/09/21 02:24 PM
08/09/21 02:24 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Well I'm an idiot. My car is 3500+ with me in it. I expect it to to 8.70's. Doing it with a Bischoff 574 B1MC motor making 1060 hp naturally aspirated no power adders. I'm old school......... Hope to hit the track in a few weeks.
At 3100 lbs, I think you only need 850 hp. Easy to do.
Re: 8.99 @ 3100lbs? [Re: JERICOGTX] #2952064
08/09/21 02:43 PM
08/09/21 02:43 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
1st of all I’m checking Mapquest and seeing what’s closer…. Sonoma CA, Mission BC, Cecil Co MD. If I’m rainbow chasing I want to hit the easy button right off the bat! laugh2
Re: 8.99 @ 3100lbs? [Re: J_BODY] #2952066
08/09/21 02:48 PM
08/09/21 02:48 PM
MN
MN
Originally Posted by J_BODY
1st of all I’m checking Mapquest and seeing what’s closer…. Sonoma CA, Mission BC, Cecil Creek MD. If I’m rainbow chasing I want to hit the easy button right off the bat! laugh2
Not Thunder Valley? LOL.
Re: 8.99 @ 3100lbs? [Re: J_BODY] #2952071
08/09/21 03:02 PM
08/09/21 03:02 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Cecil County MD.......
....BAD A$$ STREET CAR.....
Re: 8.99 @ 3100lbs? [Re: JERICOGTX] #2952072
08/09/21 03:03 PM
08/09/21 03:03 PM
N
n20mstr Offline
n20mstr  Offline
N
Sorry all i know is BB nitrous. Last NA pass i made at 3400lbs was 10.40 LMAO
Re: 8.99 @ 3100lbs? [Re: markz528] #2952074
08/09/21 03:04 PM
08/09/21 03:04 PM
N
n20mstr Offline
n20mstr  Offline
N
3500??? and what are you waiting for??? hasnt it been done for a while now???
Re: 8.99 @ 3100lbs? [Re: JERICOGTX] #2952075
08/09/21 03:04 PM
08/09/21 03:04 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Sonoma Raceway does not have a Summit ET Series Team/Program this year or years going forward. If You didn't make the Div 7 Lucas Oil Sportsman Race (done this year) or the Camping Word Pro Nationals (done as well) You're not going to run at Sonoma any time this Calendar year (2021). Sac Raceway has a variety of Dates coming up if You feel like driving and Sac is a lot closer than Mission or Cecil Creek? Famosa Raceway still has ANRA and Team Famoso races on the Calendar but It will be hot just like Sacramento. You're in Arizona correct? Las Vegas, Firebird in Idaho and Tucson in Arizona sound like realistic choices.
Re: 8.99 @ 3100lbs? [Re: markz528] #2952076
08/09/21 03:05 PM
08/09/21 03:05 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We go 9.50's @ 4023lb (w/d). Using a not too radical 900hp 580 wedge N/A. Pretty sure we'd bust the 8's @ 3100lb
Re: 8.99 @ 3100lbs? [Re: JERICOGTX] #2952077
08/09/21 03:06 PM
08/09/21 03:06 PM
N
n20mstr Offline
n20mstr  Offline
N
Serious note.....572 B! 13:1+ compression Large roller cam, SLR will need experimentation and im bad with NA, LOL but i would think 3 speed with 4.30? Ask Al ALguire for sure
Re: 8.99 @ 3100lbs? [Re: JERICOGTX] #2952080
08/09/21 03:13 PM
08/09/21 03:13 PM
AndyF Online content
AndyF  Online Content
One of the EFI cars that I help tune runs 8.90 to 9.00. It is a Studebaker with a 565 BB Chevy engine. Weighs around 3200 or 3300 lbs and makes close to 900 hp. He has a 3.89 rear gear with a Powerglide. Fairly easy engine to build in the BB Chevy world, not too hard to round up the parts to make a 900 hp BB Mopar. You would want an aftermarket block and decent heads, maybe 345 -1 heads or something along that line. Or just build a 572 with 572-13 heads. Costs a little more to build up front but you'll have 1000 hp which should put you deeper into the 8's and it could last a long time if you go with a mellower camshaft.
Re: 8.99 @ 3100lbs? [Re: AndyF] #2952085
08/09/21 03:23 PM
08/09/21 03:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Shoot for at least an honest 850hp STP.
Might take more depending on the track conditions, car efficiency, etc.
Re: 8.99 @ 3100lbs? [Re: fast68plymouth] #2952099
08/09/21 04:14 PM
08/09/21 04:14 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
At 3000lb car w/o driver. You will need every bit of 925hp. And hope your suspension can support it.
Re: 8.99 @ 3100lbs? [Re: Sammy] #2952107
08/09/21 04:29 PM
08/09/21 04:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
One fiddy + mph….
Re: 8.99 @ 3100lbs? [Re: n20mstr] #2952143
08/09/21 06:29 PM
08/09/21 06:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
In Jeff’s B bod that’s definitely the direction I’d be looking….
I’d like to hit that 8 sec mark…. But my bucket of mph is empty. 4-5 more would seal the deal
Re: 8.99 @ 3100lbs? [Re: J_BODY] #2952158
08/09/21 07:05 PM
08/09/21 07:05 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Call Goodwin
Re: 8.99 @ 3100lbs? [Re: FastmOp] #2952167
08/09/21 07:42 PM
08/09/21 07:42 PM
gregsdart Offline
gregsdart  Offline
Jeff i dynoed about 847 with my 528 on alky and managed 8.78 at BIR on MT radial 14.5 x 33 slicks, torqueflite, 3000 lbs+. With a stick and another 50 to 100 lbs you will be on the edge on a good day IMHO.
At least fully ported 440-1 heads, 3X INTAKE 284/296/114 cam with .800+ lift and some serious valve springs, rockers and pushrods, 14+ compression and I like injected alky. If you come up short a tenth fatten the injecters about 8 % and run M5 alky.
Re: 8.99 @ 3100lbs? [Re: gregsdart] #2952264
08/09/21 10:38 PM
08/09/21 10:38 PM
MN
MN
Greg, what rear gear do you currently have in the car?
Re: 8.99 @ 3100lbs? [Re: JERICOGTX] #2952303
08/10/21 03:10 AM
08/10/21 03:10 AM
Queensland,Australia
T-bar Offline
T-bar  Offline
I'm at about 3600 lbs motor went 1060 hp on engine dyno but the real problem i have been having is traction on the hit.
Re: 8.99 @ 3100lbs? [Re: T-bar] #2952321
08/10/21 07:43 AM
08/10/21 07:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My -1 Indy headed motor has run a bunch of 9.05 at 3330lbs earlier this year in subpar air. 10.5 tires off the footbrake. Best of 9.0@150@3350 running Eddy carbs
Doug
Page 1 of 3 1 2 3
