Primer or not? #2952114
08/09/21 05:00 PM
08/09/21 05:00 PM
California
mickm Offline OP
mickm  Offline OP
California
Painting a fresh oil pan with Mopar paint. I have some self etching primer, is that going to make for a more durable surface?
Any hints, like would it help to lightly sand with 400 grit before the primer or paint if not using primer?
Re: Primer or not? [Re: mickm] #2952152
08/09/21 06:51 PM
08/09/21 06:51 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Paint bonds by 2 means: Chemically or Mechanically .
That addresses both your concerns about "more durable finish" wrt adhering.
WRT to "finish", that's a factor of the type paint you use.
Re: Primer or not? [Re: PhillyRag] #2952234
08/09/21 09:30 PM
08/09/21 09:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd clean, sand, prime, and paint.
I always do on tin, and the paint's held up on every one - oldest still here is 30 years old.
Re: Primer or not? [Re: topside] #2952809
08/11/21 01:16 PM
08/11/21 01:16 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Some self etching primers require a primer surfacer before topcoat, just FYI.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Primer or not? [Re: 5wndwcpe] #2952891
08/11/21 05:44 PM
08/11/21 05:44 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I've done it all ways and haven't been able to notice too much of a difference. I've sprayed the Mopar paint on bare metal, straight over etching primer and over filler primer. I will say that the filler primer parts have probably held up the best but, not by enough that I would say it's worth it.
The etch primer I used was Dupli-Color rattle can and the filler primer was PPG that I gun sprayed. Probably not applies to apples here since any 2k product is going to be better than rattle can.
Re: Primer or not? [Re: parksr5] #2952901
08/11/21 06:17 PM
08/11/21 06:17 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Sand the pan and use some epoxy primer. You can get it in rattle cans but don't expect to see it in you local home improvement store.
https://www.spraymax.com/en-us/products/product/primer-primer-filler/2k-epoxy-primer-1/
