Re: A518 torque converter help
[Re: mcat4321]
#2952108
08/09/21 04:33 PM
08/09/21 04:33 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
PATC , not PTC is what I have, not high HP about 650ish in a 68 512 cid Charger street car, it is a lock up but only for light throttle, they do make multi disc converters, I had them build it for my combination & it was right on the money 4200 flash, when I had a Carb, now it flashes a little over 5k with the Hilborn EFI & long runners. drives great on the street.
[Re: CSK]
#2952130
08/09/21 05:56 PM
08/09/21 05:56 PM
Posts: 1,397 Toronto Ontario, Can
Glen440
I ordered a Patc 10" lockup back in April. They cannot get parts when I checked up on it in June.
Someone else makes one, I'm not sure who it is. Crt transmission has a video with one and I thought he said Ultimate converter. I phoned Ultimate and they told me they do not have an aftermarket lockup for the 727/518. Maybe have to order through crt.
I ended up having the stock 11" freshened, they couldn't do much for the stall speed. I don't need high stall yet so I can wait for now.
87 dakota 6.1 hemi
[Re: Glen440]
#2952136
08/09/21 06:18 PM
08/09/21 06:18 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
IF you are not married to the lock up I bet you can change the pump and go non lock up. That will open up your options a ton. In a turbo deal the converter is pretty tight most of the time so losing the lock up may not be that big of a deal.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2952138
08/09/21 06:25 PM
08/09/21 06:25 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
IF you are not married to the lock up I bet you can change the pump and go non lock up. That will open up your options a ton. In a turbo deal the converter is pretty tight most of the time so losing the lock up may not be that big of a deal. i would be all for this, but i am not fluent enough in transmissions to know if it will work that way
[Re: mcat4321]
#2952223
08/09/21 09:23 PM
08/09/21 09:23 PM
Bad340fish
Tulsa OK
IF you are not married to the lock up I bet you can change the pump and go non lock up. That will open up your options a ton. In a turbo deal the converter is pretty tight most of the time so losing the lock up may not be that big of a deal. i would be all for this, but i am not fluent enough in transmissions to know if it will work that way You might call the guys at A&A transmission, or hope Transman or John Kunkel(spelling?) answer you.
[Re: CSK]
#2952606
08/10/21 07:54 PM
08/10/21 07:54 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
PATC , not PTC is what I have, not high HP about 650ish in a 68 512 cid Charger street car, it is a lock up but only for light throttle, they do make multi disc converters, I had them build it for my combination & it was right on the money 4200 flash, when I had a Carb, now it flashes a little over 5k with the Hilborn EFI & long runners. drives great on the street. Are you aware of someone making a multi disc converter for 518 gas trans? Only multi discs I have found are for the diesel trans.
[Re: mgoblue9798]
#2952619
08/10/21 08:24 PM
08/10/21 08:24 PM
CSK
Pattison Texas
PATC , not PTC is what I have, not high HP about 650ish in a 68 512 cid Charger street car, it is a lock up but only for light throttle, they do make multi disc converters, I had them build it for my combination & it was right on the money 4200 flash, when I had a Carb, now it flashes a little over 5k with the Hilborn EFI & long runners. drives great on the street. Are you aware of someone making a multi disc converter for 518 gas trans? Only multi discs I have found are for the diesel trans. PATC said they could back when I had mine built. mine has Diesel internals ??
[Re: Glen440]
#2954661
08/17/21 01:12 PM
08/17/21 01:12 PM
Posts: 69 racine,wi
70gtx1
racine,wi
I ended up having the stock 11" freshened, they couldn't do much for the stall speed. I don't need high stall yet so I can wait for now. The CRT video you are referring to , the converter is from Ultimate converter and trans https://www.facebook.com/UltimateTrans/ I actually have one of their 10 inch lockup converters in my CRT lockup 727 behind my hellcat swap 1970 GTX. It is working great so far.
[Re: 70gtx1]
#2954991
08/18/21 11:35 AM
08/18/21 11:35 AM
Glen440
I did not know there is more than one company starting with ultimate. Thanks.
I use the compushift mini controller and can lock the converter in 2nd 3rd or 4th. I did not want manual switches, it works good.
87 dakota 6.1 hemi
[Re: 70gtx1]
#2959730
08/31/21 10:26 PM
08/31/21 10:26 PM
Posts: 767 NW PA
V10nacuda
NW PA
[quote=70gtx1] The CRT video you are referring to , the converter is from Ultimate converter and trans https://www.facebook.com/UltimateTrans/ I actually have one of their 10 inch lockup converters in my CRT lockup 727 behind my hellcat swap 1970 GTX. It is working great so far. [quote] Is yours a single disc billet piece like the diesel stuff? Is this for a race car or cruiser and whats the approx stall on that? Thinking about using the 518 behind a Hellcat for a Ramcharger..
