Mercedes fan controller #2951909
08/08/21 11:29 PM
08/08/21 11:29 PM
NW Indiana
motorhead446 Offline OP
NW Indiana
Hello, are the fan controllers created by some members here still available? Thanks
66 coronet 500
67 belvedere
70 duster
71 dart
Re: Mercedes fan controller [Re: motorhead446] #2951929
08/09/21 02:09 AM
08/09/21 02:09 AM
hooziewhatsit Offline
Re: Mercedes fan controller [Re: hooziewhatsit] #2951950
08/09/21 08:13 AM
08/09/21 08:13 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Originally Posted by hooziewhatsit
And work great. up
Master, again and still
Re: Mercedes fan controller [Re: DaveRS23] #2952030
08/09/21 12:14 PM
08/09/21 12:14 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
And work great. up
"The Best or Nothing" wink up up
Re: Mercedes fan controller [Re: hooziewhatsit] #2952275
08/09/21 11:13 PM
08/09/21 11:13 PM
NW Indiana
NW Indiana
Thanks! I'll be placing an order soon.
66 coronet 500
67 belvedere
70 duster
71 dart
Re: Mercedes fan controller [Re: motorhead446] #2952356
08/10/21 09:55 AM
08/10/21 09:55 AM
moparx Offline
moparx  Offline
how would one of these work on a dual fan setup from a 2012 chrysler 300 ?
as compared to a derale PWM controler used on the above fan ?
beer
Re: Mercedes fan controller [Re: moparx] #2952396
08/10/21 11:09 AM
08/10/21 11:09 AM
beer
My controller only works with the Mercedes fan (or possibly some BMW ones too work).
The MB fan has four wires going to it; two large ones for power and ground, and two small signal wires.
Most other fan controllers can work with fans that only have the two large power wires, by interrupting the power going through the fan.
The MB fan has an onboard computer that takes the PWM signal from my controller, and uses that to control the fan speed.
It looks like the dual fan from the 300 only has two power wires to each fan, so it will not work with my controller.
Re: Mercedes fan controller [Re: hooziewhatsit] #2952470
08/10/21 01:56 PM
08/10/21 01:56 PM
moparx Offline
moparx  Offline
yes, just two wires to each fan.
i'm up in the air about what to use for a controller. there are several PWM units out there, or just wire through [a] relay[s].
i don't know........... runaway
beer
Re: Mercedes fan controller [Re: moparx] #2952835
08/11/21 03:24 PM
08/11/21 03:24 PM
GA
roadrunninMark Offline
GA
You can get a good MB fan from the junkyard, I think I paid under 60 for it. It fits a 26" radiator nicely with a little trimming. (this is an ECS radiator).
Re: Mercedes fan controller [Re: moparx] #2952839
08/11/21 03:32 PM
08/11/21 03:32 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Autocoolguy.com
This is the controller you need. I bought a 125amp unit. And he has higher ones.
Look at the feedback on the best ones that Summit sells. A lot of failures.
I also have one of howisits (member here) controller for my Mercedes fan and it works great. It’s probably 8 years old, one of his first ones.
Re: Mercedes fan controller [Re: rapom] #2952931
08/11/21 07:11 PM
08/11/21 07:11 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Which MB C class fan assy.203 chassis or 204,or what part#.
Read the original post fans are from the C class W203 chassis 2000/07
Re: Mercedes fan controller [Re: 71GTX471] #2952977
08/11/21 08:49 PM
08/11/21 08:49 PM
GA
GA
If I remember correctly, it is all "C" class cars, 03-08 but double check... here is the original thread. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2767866/1.html
Re: Mercedes fan controller [Re: roadrunninMark] #2953028
08/11/21 11:39 PM
08/11/21 11:39 PM
Basically, if the plug looks like this, it will work. There's an 850w fan I know works that I can try to find the part number for.
http://ma-uav.com/images/Fan%20Plug%20and%20harness%202.jpg
I had come across some other model that did not use that plug, but had two large power wires, and two small signal wires, and would probably work as well.
Re: Mercedes fan controller [Re: motorhead446] #2953403
08/13/21 11:10 AM
08/13/21 11:10 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It's nice to see this is still going strong.
- Stu Harmon
