Anyone build their own Dana 60? How to id a good housing?
#2951504
08/07/21 09:17 PM
08/07/21 09:17 PM
Posts: 21,638 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Budget for the Cuda got cut again, so now I have to figure out where to cut it from. Was going to order a Dana 60, But I can afford it. I was lucky enough to score for free a late 70’s ford Dana 60 3/4 ton rearend for free, so I think that might be the way to do. Though it says D60 on one of the diff corners, I know a few fords came with a Dana ‘61’ style rearend. I don’t know if that is the same or not as a Dana housing, but very little is available for that rear. So anybody exterior wise the difference from a 60/61 case, and how would you build it for an street/strip car?
Re: Anyone build their own Dana 60? How to id a good housing?
[Re: migsBIG]
#2951533
08/08/21 03:09 AM
08/08/21 03:09 AM
Posts: 771 Btween a rock and a hard place
moparlulu
Some differences for sure between the two. ive done 3 8 3/4 to dana swaps I’ve bought ends and perches from dr diff. cut and welded the ends myself using a friends kit the first time. made My own and used on the other two. With new everything,ie. spool, begs axles( had the gear sets I was into it 800.00 us.
[Re: moparlulu]
#2951615
08/08/21 11:33 AM
08/08/21 11:33 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Is there a six-digit number stamped into one of the axle tubes which gives you that info? I know the Dana 70 in my Ford flatbed was easily identified that way. Speaking of which, has anyone built a D70 from a truck rear? It's an even bigger ring gear than the 60, and usually has a 4.10 or deeper...
[Re: DrCharles]
#2951634
08/08/21 12:12 PM
08/08/21 12:12 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
Is there a six-digit number stamped into one of the axle tubes which gives you that info? I know the Dana 70 in my Ford flatbed was easily identified that way. Speaking of which, has anyone built a D70 from a truck rear? It's an even bigger ring gear than the 60, and usually has a 4.10 or deeper... Sox put one in his early pro stockers back in the 70s or 80s
[Re: DrCharles]
#2951658
08/08/21 12:55 PM
08/08/21 12:55 PM
Posts: 43,115 Bend,OR USA
Cab_Burge
I bought a Dana 70 out of John Deanna old duster, it had 6.87 gears in it. I swap them out to a used set of 5.38 ratio out of a Ford truck Dana 70 that I had swap a set of 4.10 into for a friend. That truck was a 1960 one ton ramp truck that had a 3 speed over, direct and under drive auxiillary(SP?)also known as a Brownie in line tranny.
[Re: Cab_Burge]
#2951842
08/08/21 08:10 PM
08/08/21 08:10 PM
migsBIG
San Jose,CA
Didn't know folks were using the dana 70, though it was always the 60. good to know. So for a fairly heavy car (1970 CUDA, all steel, iron block, 10.5 tire), who makes a strong axle that would be good for it? Tru-Trac or a locker diff? I'm probably going to farm out the mechanicals as have the proper equipment.
[Re: migsBIG]
#2951863
08/08/21 08:44 PM
08/08/21 08:44 PM
Cab_Burge
35 spline street and strip axles with a good clutch type posi worked forever in street racing for many years for many racers running low 8s on the street back in the day. My S/P car has Mark Williams 40 spline axles and spool
[Re: migsBIG]
#2951958
08/09/21 08:31 AM
08/09/21 08:31 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
The factory style powerlock diff is really strong.
The one I built for my dad's road runner was probably the cheapest ever, lol. Bought the complete rear for $150 from under a '70s dodge truck IIRC. It came w/ a powerlock diff., good 3.54 gear, and surprisingly it had a 1350 yoke on it. All I bought for it was new 35 spline axles, 35 spline side gear and rebuild kit for the diff., housing ends and perches...all from Dr. Diff. Good friend of mine narrowed it and welded it all up. Built it myself.
Did the same thing for the Dana under my other road runner. Craigslist Dana 60 from a '70s Ford truck (had a bad ring and pinion and the weaker tracklock diff.) for $125. Used 4.10 gear from moparts for $75, spool, axles, ends, 1350 yoke, and perches from Dr. Diff.
[Re: 6pakdakota]
#2952135
08/09/21 06:16 PM
08/09/21 06:16 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Mine came out of an old F350 for $100. Local guy cut it down and welded on Moser ends for $150 and set the gears up for $100.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2952172
08/09/21 07:50 PM
08/09/21 07:50 PM
migsBIG
San Jose,CA
Sweet diff! Is that a moser cover? That looks THICC! That would be great for added strength. I just got off the phone with the only builder in my area and they don't fab work anymore, they just assemble now. Though If I can do all the mods myself or someone I know, they said they could assemble everything for $500 and I supply all the parts, which is cheap insurance since I've never built one before.
[Re: migsBIG]
#2952220
08/09/21 09:20 PM
08/09/21 09:20 PM
Posts: 4,457 Washington
madscientist
Washington
Sweet diff! Is that a moser cover? That looks THICC! That would be great for added strength. I just got off the phone with the only builder in my area and they don't fab work anymore, they just assemble now. Though If I can do all the mods myself or someone I know, they said they could assemble everything for $500 and I supply all the parts, which is cheap insurance since I've never built one before. Skip the cover and buy aftermarket caps.
[Re: migsBIG]
#2952260
08/09/21 10:25 PM
08/09/21 10:25 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
Sweet diff! Is that a moser cover? That looks THICC! That would be great for added strength. I just got off the phone with the only builder in my area and they don't fab work anymore, they just assemble now. Though If I can do all the mods myself or someone I know, they said they could assemble everything for $500 and I supply all the parts, which is cheap insurance since I've never built one before. Fearless Gear in Fresno?
[Re: migsBIG]
#2952266
08/09/21 10:44 PM
08/09/21 10:44 PM
cudaman1969
fredericksburg,va
Sweet diff! Is that a moser cover? That looks THICC! That would be great for added strength. I just got off the phone with the only builder in my area and they don't fab work anymore, they just assemble now. Though If I can do all the mods myself or someone I know, they said they could assemble everything for $500 and I supply all the parts, which is cheap insurance since I've never built one before. That’s steep to just set it up. $200 for me
[Re: madscientist]
#2952293
08/10/21 12:33 AM
08/10/21 12:33 AM
Cab_Burge
Sweet diff! Is that a moser cover? . Skip the cover and buy aftermarket caps. I disagree I would and have bought both the preload covers and 2 steel caps for both sides on a Dana 60 for high output(2500+ HP) use
