Re: Down on oil pressure.
[Re: FastmOp]
#2949691
08/02/21 01:23 PM
08/02/21 01:23 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
What did you find that would cause the pressure loss?
[Re: FastmOp]
#2949711
08/02/21 02:23 PM
08/02/21 02:23 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Not bad at all! Hopefully you can find the parts you need and get it back together!
[Re: FastmOp]
#2949921
08/03/21 08:30 AM
08/03/21 08:30 AM
an8sec70cuda
[Re: FastmOp]
#2949942
08/03/21 09:51 AM
08/03/21 09:51 AM
Posts: 4,209 New York
polyspheric
New York
What weight oil? What windage and G force controls in the pan?
Boffin Emeritus
[Re: Dragula]
#2949955
08/03/21 10:40 AM
08/03/21 10:40 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I had to go to an oil accumulater, 3 qt. Next would be some way to monitor the pressure for dips or loss, like a data logger (best) or go pro camera. I also run a large diameter line to the gauge so it responds quickly.
[Re: gregsdart]
#2950002
08/03/21 01:33 PM
08/03/21 01:33 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I had some bearings that had splotches like that but were smooth and not torn up at all. Everything I read was that aereation caused it. And sure enough my oil pump pickup broke off in my hand because it was cracked at the threads.
Oddly enough the main bearings were very splotchy and looked horrible but the rods were absolutely mint with zero sign of wear.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2950069
08/03/21 04:26 PM
08/03/21 04:26 PM
TRENDZ
Milwaukee WI
Oddly enough the main bearings were very splotchy and looked horrible but the rods were absolutely mint with zero sign of wear. Im not familiar with his pump supply, but finding silicone before the pump would cause cavitation even with a completely sealed pickup. Pumping aerated oil is no good. Especially in a beast like this. I also put merit in the link posted by dvw. Either or both could apply in this case.
