Re: solid roller lifters in an unbushed RB block
[Re: Stanton]
#2950886
08/05/21 10:27 PM
08/05/21 10:27 PM
Posts: 1,262 New York, USA
Chargerfan68
New York, USA
The Comp Sportsman bushed are very nice and pricey, but they are made on the small spec. I’ve used them on my motor and another guys motor. Both have a little excessive clearances and lower oil pressure at idle. Both ended up at between .029” and .033” lifter/bore. So i wouldn’t use them again on a stock unbushed block. Just my experience and fyi
[Re: DGS]
#2950964
08/06/21 09:26 AM
08/06/21 09:26 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Don’t have the specific info you are looking for. I do have relevant info though. I have used bams in sbc engines. They are high quality. As far as your application, I would suggest the solid body crower lifter. No oil band cut to deal with.
[Re: Chargerfan68]
#2950967
08/06/21 09:35 AM
08/06/21 09:35 AM
Posts: 4,205 New York
polyspheric
New York
.029” and .033” lifter/bore Did you mean .0029" and .0033"? What you wrote has no oil pressure.
Boffin Emeritus
[Re: polyspheric]
#2950992
08/06/21 10:35 AM
08/06/21 10:35 AM
Chargerfan68
New York, USA
.029” and .033” lifter/bore Did you mean .0029" and .0033"? What you wrote has no oil pressure. Sorry….yes i meant .0029-.0033” clearances.
[Re: Chargerfan68]
#2951049
08/06/21 12:54 PM
08/06/21 12:54 PM
Posts: 19,239 north of coder
moparx
.029” and .033” lifter/bore Did you mean .0029" and .0033"? What you wrote has no oil pressure. Sorry….yes i meant .0029-.0033” clearances. i was wondering myself how any oil pressure was produced with .029 clearance in the lifter bore ! glad that was a MIS-print !
[Re: moparx]
#2951054
08/06/21 01:16 PM
08/06/21 01:16 PM
Posts: 8,828 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
No oil band cut to deal with The oil band isn't the issue, the issue is exposing the oil passage at full lift because the wheel isn't shrouded.
[Re: Stanton]
#2951242
08/06/21 11:06 PM
08/06/21 11:06 PM
Posts: 10,549 Rittman Ohio
fourgearsavoy
Rittman Ohio
The BAM lifters on the Hughs Engines site advertises fully skirted roller wheel pocket so there shouldn't be an issue. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2951269
08/07/21 01:12 AM
08/07/21 01:12 AM
Posts: 702 Lake Villa Il
INTMD8
Lake Villa Il
Would like to see a photo of that. I've not seen a set of bam lifter fully shrouded, as to do so would compromise wheel diameter. (but possible, sure).
What I did is order lifters first, then drop them to within .100 of uncovering oil gallery to determine base circle. Then from there, bring it to .100 of max lift before uncovering oil gallery to determine max lobe lift.
Probably could go further but didn't need to for what I'm trying to do.
Guess what I'm trying to say is, if you're trying to get the most out of an unbushed block, IMO, the best you can do is measure.
[Re: INTMD8]
#2951931
08/09/21 04:16 AM
08/09/21 04:16 AM
Posts: 635 Graz, Austria
DGS
Graz, Austria
Yeah, I was thinking about doing the same (measuring). A smaller base circle is one of the options (besides bushing the block) to make non skirted lifters work. The BAM Chrysler roller lifters all have a .815" wheel - no idea if skirting is possible with the bigger wheel and a .903" diameter...
[Re: INTMD8]
#2952739
08/11/21 09:34 AM
08/11/21 09:34 AM
Posts: 35 Canada
Criterion
Canada
Would like to see a photo of that. I've not seen a set of bam lifter fully shrouded, as to do so would compromise wheel diameter. (but possible, sure). These are the BAM lifters with the 0.815" rollers: http://www.hughesengines.com/Index/...amp;level1=TGlmdGVycw==&partid=31343I bought mine 6 years ago when MRL had started selling them and they have proven to be excellent in my application (unbushed 400 block, street roller w/ ~0.640" gross lift w/ 1.5:1 rockers). I did have to do some clearancing on the passenger side-rear of the valley, because the link-bars are thicc boys that would rub the block.
[Re: Criterion]
#2952769
08/11/21 11:13 AM
08/11/21 11:13 AM
INTMD8
Lake Villa Il
^ Thanks, I've never seen those.
