What does this cam card tell? #2950236
08/03/21 10:24 PM
08/03/21 10:24 PM
Super Spudsville
Mr PotatoHead Offline OP
Half Baked
Half Baked
Super Spudsville
What do you glean from this cam card?
Yes its old as heck, is it street/strip strip only for its time period?
TIA
STOP POTATO HATE!
Re: What does this cam card tell? [Re: Mr PotatoHead] #2950242
08/03/21 10:58 PM
08/03/21 10:58 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
What do you want to know? It's .500 lift and 300 duration with 84 degrees of overlap....not likely a grocery getter camshaft
Re: What does this cam card tell? [Re: Mr PotatoHead] #2950244
08/03/21 11:01 PM
08/03/21 11:01 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I bet its somewhere around 250 @ .050 so probably 3500-6500 and probably recommends 11 to 1 my twocents
Re: What does this cam card tell? [Re: B1MAXX] #2950262
08/04/21 01:40 AM
08/04/21 01:40 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Hot little cam from back in the day.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What does this cam card tell? [Re: Mr PotatoHead] #2950267
08/04/21 02:09 AM
08/04/21 02:09 AM
it is a old symmetrical single pattern solid lifter grind for SB Mopars V8 shruggy
As far as it intended use and what your willing to live with are determined by YOU up scope
I wouldn't hesitate to use it for a New York second on a decent street and strip motor up twocents
If I really wanted a hot nasty street cam I would buy and use a newer roller cam twocents
Re: What does this cam card tell? [Re: Cab_Burge] #2950301
08/04/21 09:07 AM
08/04/21 09:07 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
there's really not enough info on that card. the "wild card" to this is at what lobe lift were the timing numbers taken? that's a big deal with any cam but especially a solid. if those numbers are running timing events at .030" lash then that's a big cam for a small block.
Re: What does this cam card tell? [Re: lewtot184] #2950314
08/04/21 09:26 AM
08/04/21 09:26 AM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Great replies, I really appreciate it.
Im thinking about tossing it in a lil 4 inch stroke short block I just did, I love the old day two stuff and most all my junk has pretty deep gears and I dont think I own a stock vert for anything.
This ride has a old set of dougs 4 inch side pipes I can adjust the packing for the right noise, so rough idle and raw and stinky fuel is great for a day 2 real street car. Like the ones we used to burn a tank a night, night after night.
STOP POTATO HATE!
Re: What does this cam card tell? [Re: Mr PotatoHead] #2950322
08/04/21 09:52 AM
08/04/21 09:52 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Back in the 70's I put a JC Whitney 500 lift 300 duration cam in my '69 340 Swinger, with a factory intake, headers, 3500 B&M Super Holeshot convertor & 4.56 gears it ran 12.88. It was a hydraulic cam though. Sounded great.
Re: What does this cam card tell? [Re: GODSCOUNTRY340] #2950332
08/04/21 10:27 AM
08/04/21 10:27 AM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
I recall these guys having a couple maybe like speed shops in the early 70-s and this probably came from there vs there shop.
STOP POTATO HATE!
Re: What does this cam card tell? [Re: Mr PotatoHead] #2950334
08/04/21 10:31 AM
08/04/21 10:31 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
That can card tells me 10 to 1 compression or more. Could seek by with a 340 10 inch converter and 391 or 410 in a rear end or would be slow but sound good.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
