Down on oil pressure. #2949648
08/02/21 11:20 AM
08/02/21 11:20 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Took Ka-Blue-E to track, after a few hits was down 20 pounds after a run. Pulled motor and found a few small issues but nothing hurt too bad.
I think I'll replace bearings and rings. And add top fuel hoops and get away from the Cometic head gasket. Plan on turning it up some if I can get a better material stud. Need the heads refreshed, seem like some excess leakage past the valves.
It's the 1st time it's been out since 2015
Not bad for a 4 second power plant.
Re: Down on oil pressure. [Re: FastmOp] #2949691
08/02/21 01:23 PM
08/02/21 01:23 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
What did you find that would cause the pressure loss?
Re: Down on oil pressure. [Re: TRENDZ] #2949692
08/02/21 01:26 PM
08/02/21 01:26 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Looked like RTV broke down and got pumped through system. Small pieces from edge of oil pan it looks like. I guess at 7800 the oil was hard on it.
Re: Down on oil pressure. [Re: FastmOp] #2949711
08/02/21 02:23 PM
08/02/21 02:23 PM
an8sec70cuda Offline
Not bad at all! Hopefully you can find the parts you need and get it back together!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Down on oil pressure. [Re: an8sec70cuda] #2949819
08/02/21 09:21 PM
08/02/21 09:21 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I took some pics of the bearings
I'm surprised the heads are so beat up. I need to get them done asap. MoParty is coming fast.
Re: Down on oil pressure. [Re: FastmOp] #2949821
08/02/21 09:26 PM
08/02/21 09:26 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Number 8 and 5
See the gray. It no Bueno
Re: Down on oil pressure. [Re: FastmOp] #2949921
08/03/21 08:30 AM
08/03/21 08:30 AM
Oil starvation?
CHIP
Re: Down on oil pressure. [Re: FastmOp] #2949942
08/03/21 09:51 AM
08/03/21 09:51 AM
New York
polyspheric Offline
polyspheric  Offline
New York
What weight oil?
What windage and G force controls in the pan?
Boffin Emeritus
Re: Down on oil pressure. [Re: an8sec70cuda] #2949950
08/03/21 10:31 AM
08/03/21 10:31 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Originally Posted by an8sec70cuda
Oil starvation?
That would be my guess when its #7 or #8, they are last in the supply line.....Can be a number of reasons. The RTV that the OP suggested is a strong possibility. I am not a guru of oil return science, but I have learned over the years, getting it back to the pan as quick as possible is big insurance against oil starvation. Suppling it is easy, returning it quickly enough is often an issue.
Re: Down on oil pressure. [Re: Dragula] #2949955
08/03/21 10:40 AM
08/03/21 10:40 AM
gregsdart Offline
gregsdart  Offline
I had to go to an oil accumulater, 3 qt. Next would be some way to monitor the pressure for dips or loss, like a data logger (best) or go pro camera. I also run a large diameter line to the gauge so it responds quickly.
Re: Down on oil pressure. [Re: gregsdart] #2950002
08/03/21 01:33 PM
08/03/21 01:33 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had some bearings that had splotches like that but were smooth and not torn up at all. Everything I read was that aereation caused it. And sure enough my oil pump pickup broke off in my hand because it was cracked at the threads.
Oddly enough the main bearings were very splotchy and looked horrible but the rods were absolutely mint with zero sign of wear.
68 Barracuda Formula S 340
Re: Down on oil pressure. [Re: Bad340fish] #2950041
08/03/21 03:00 PM
08/03/21 03:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd look here. It looks like illustration #19 to me. Makes sense based on the fact that there is plenty of load on this engine.
https://www.mahle-aftermarket.com/m...114-engine-bearing-failures-brochure.pdf
Doug
Re: Down on oil pressure. [Re: Bad340fish] #2950069
08/03/21 04:26 PM
08/03/21 04:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Im not familiar with his pump supply, but finding silicone before the pump would cause cavitation even with a completely sealed pickup.
Pumping aerated oil is no good. Especially in a beast like this.
I also put merit in the link posted by dvw. Either or both could apply in this case.
Re: Down on oil pressure. [Re: FastmOp] #2950302
08/04/21 09:07 AM
08/04/21 09:07 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Best of luck getting it rebuilt in a short time. Isn't this a 'source' crank? What were your bearing clearences? How much boost?
Re: Down on oil pressure. [Re: HardcoreB] #2950320
08/04/21 09:44 AM
08/04/21 09:44 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Crank looks good so far. Yes it's a 440 source crank. I'll die check it this weekend but it looks good.
No gray in the pump pickup. It was small pieces that built up in the rod throw oil holes. Had some in the filter as well. You can see the rtv in the oil hole of the crank in pic.
Have a few lifters spread slightly, nothing major but need replaced. All wheels roll sweet still.
About 20 psi. I keep my clearances to myself. I'm not going to give away everything.
3 runs ago was a new best ET at 4.800 4 runs ago was new best MPH at 162. Turning 7600 or so
Re: Down on oil pressure. [Re: FastmOp] #2950512
08/04/21 08:10 PM
08/04/21 08:10 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Anyone faster with a 440Source crank ?
Re: Down on oil pressure. [Re: FastmOp] #2950544
08/04/21 10:14 PM
08/04/21 10:14 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
HolyXXX! I assumed you had a 'short stroke' crank in that??? Like a 3.75" etc?
Re: Down on oil pressure. [Re: HardcoreB] #2950800
08/05/21 06:51 PM
08/05/21 06:51 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Here is the gray rtv. It was so small it went through the pickup.
Re: Down on oil pressure. [Re: FastmOp] #2951016
08/06/21 11:25 AM
08/06/21 11:25 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I gave up using RTV long ago because of that,
Almost without exception Permatex red Spray-a-Gasket has kept our engine dry.
Joe
Re: Down on oil pressure. [Re: FastmOp] #2951044
08/06/21 12:46 PM
08/06/21 12:46 PM
Those pieces looks like they got made a lot smaller going through the pump work twocents shruggy
