Race Car wiring #2949605
08/02/21 09:01 AM
08/02/21 09:01 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
What connectors do you use when wiring a race car? Which ones handle higher amperages? Seems like the weather pack connectors melt down at 30amps.
Re: Race Car wiring [Re: Dragula] #2949649
08/02/21 11:21 AM
08/02/21 11:21 AM
Texas
RustyM Offline
RustyM  Offline
Texas
I just use real 3M connectors rated for for the circuit im wiring. On many areas i prefer "non- insulated" and just use good quality heat shrink. I seem to get more consistent crimps ( weld joints) with non- insulated connectors.
FWIW
Re: Race Car wiring [Re: Dragula] #2949659
08/02/21 11:45 AM
08/02/21 11:45 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use kind of a mix of Metripack and weatherpack. I haven't had any issues yet. My fan plug can be questionable but it plugs directly into the fan and its a cheapo deal so I don't fault the connector.
I think the flagship is the Deutsh(spelling) connectors. They can get expensive and the good crimping tools can also be expensive.
68 Barracuda Formula S 340
Re: Race Car wiring [Re: Bad340fish] #2949669
08/02/21 12:30 PM
08/02/21 12:30 PM
Dragula Offline OP
Dragula  Offline OP
My weather pack ones for the fans, are the ones that melted down....Where do you guys source the good connectors and stuff?
Re: Race Car wiring [Re: Bad340fish] #2949670
08/02/21 12:33 PM
08/02/21 12:33 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I used Deutsch connectors where ever possible on my Road Runner. So much nicer than Weather pack, or metri pack connectors. I have access to all three at work. I save all the connectors when we scrap out machines, and just buy new pins for them.
69 GTX 68 Road Runner
Re: Race Car wiring [Re: JERICOGTX] #2949688
08/02/21 01:21 PM
08/02/21 01:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
30 amps is a bunch, for anything other than a starter on a race car. Weatherpacks are made for up to 10-12 gauge which should handle 30A fine. Is the motor a problem? Never seen one even half that. I've never had a hint of a problem with the Weatherpack stuff..
Is that one fan or multiples? On multiples, I use a separate relay and wiring for each motor.
Re: Race Car wiring [Re: CMcAllister] #2949721
08/02/21 03:12 PM
08/02/21 03:12 PM
Dragula Offline OP
Dragula  Offline OP
Each fan had its own supply wire, but I put the grounds to one common one thru the weather pack.....So it was closer to 2 fans x 27amps each....
Re: Race Car wiring [Re: Dragula] #2949726
08/02/21 03:32 PM
08/02/21 03:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Try splitting the grounds to individuals all the way to the stud, chassis, buss or whatever the main ground is.
Re: Race Car wiring [Re: CMcAllister] #2949827
08/02/21 09:37 PM
08/02/21 09:37 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I just use spade connections
Re: Race Car wiring [Re: FastmOp] #2949847
08/02/21 10:41 PM
08/02/21 10:41 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
My fan is close to 40 amps and I use a #10 wire and the correct matching pins in a weatherpak connector. Absolutely no issues. I suspect that you either had a bad crimp or undersized wiring or pins.
Re: Race Car wiring [Re: JERICOGTX] #2950008
08/03/21 01:47 PM
08/03/21 01:47 PM
moparx Offline
moparx  Offline
i like the Deutsch connectors as well. just make sure you have a quality tool to crimp them with.
as has also been stated, sometimes you need to use an un-insulated spade, ring, or pin. i like to use the ones that are tin plated, but i have also used bare copper as well.
when using shrink tubing, i have now started to use the marine grade, which has a sealer glue inside. just seems like an extra measure of keeping a good connection between the wire and the terminal.
beer
Re: Race Car wiring [Re: JERICOGTX] #2950304
08/04/21 09:11 AM
08/04/21 09:11 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
x2!
Re: Race Car wiring [Re: HardcoreB] #2950696
08/05/21 12:35 PM
08/05/21 12:35 PM
Dragula Offline OP
Dragula  Offline OP
x2!
I was wondering if I should switch....I have a pile of weather pack connectors though.
Also, what wire labler & lables are you all using?
Re: Race Car wiring [Re: HardcoreB] #2950854
08/05/21 09:12 PM
08/05/21 09:12 PM
What are Deutsch connectors, brand or type?
How about a picture of them please luck
Re: Race Car wiring [Re: Cab_Burge] #2950927
08/06/21 01:32 AM
08/06/21 01:32 AM
North America
K
kwikblownhemi Offline
K
North America
https://www.delcity.net/store/DEUTSCH-Connectors/p_822961
Re: Race Car wiring [Re: kwikblownhemi] #2950930
08/06/21 02:10 AM
08/06/21 02:10 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The problem with Deutsch right now is in stock availability, like so much other stuff these days.
Re: Race Car wiring [Re: Cab_Burge] #2951195
08/06/21 07:52 PM
08/06/21 07:52 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Re: Race Car wiring [Re: VernMotor] #2951274
08/07/21 01:36 AM
08/07/21 01:36 AM
I'm glad I ask and you guys help me see what they make, Thanks a lot bow
Nice looking parts up
I'm use to 3M brand Scotchlock connectors and the local parts store inventory on ends.
Re: Race Car wiring [Re: Cab_Burge] #2951358
08/07/21 12:31 PM
08/07/21 12:31 PM
moparx Offline
moparx  Offline
Cab, if you are referring to the "cut into the wire squeeze with pliers-fold over cover" wire tap when you mention "scotchlocks", i rate them right up there with those "bolt on" battery terminal ends............
i REALLY don't like them ! tsk biggrin
just my opinion, your mileage will vary.
beer
Re: Race Car wiring [Re: moparx] #2951368
08/07/21 01:14 PM
08/07/21 01:14 PM
I worked for a telephone company for 33 yrs, those Scotchlok type connectors are used in that industry, insert the wires and pushdown the lock in plug wrench
3M catered to that industry, we mainly use wire gauge from 19 to 26 gauge depending on how far the customer was from the central office shruggy
One time use only also shruggy
