Cool discussion on laying a crankshaft on it's side #2949348
08/01/21 10:46 AM
08/01/21 10:46 AM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Master, again and still
Re: Cool discussion on laying a crankshaft on it's side [Re: DaveRS23] #2949368
08/01/21 11:46 AM
08/01/21 11:46 AM
AndyF Offline
AndyF  Offline
Nobody ever points out that if a crankshaft is going to bend under its own weight, it is more likely to bend when standing up than laying down. When a crank is laying down it is supported at multiple locations by the counterweights. When it is standing up all the weight is supported by the last main.
Re: Cool discussion on laying a crankshaft on it's side [Re: AndyF] #2949374
08/01/21 12:02 PM
08/01/21 12:02 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Randy Winberg who makes some of the best crankshafts in the world, told me it did not matter how a crankshaft was stored.
That is good enough for me.
Re: Cool discussion on laying a crankshaft on it's side [Re: 340Cuda] #2949393
08/01/21 01:25 PM
08/01/21 01:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I went with a buddy to Callies to pick up his crank and their inventory was all laying sideways on pallets. shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Cool discussion on laying a crankshaft on it's side [Re: fourgearsavoy] #2949399
08/01/21 02:01 PM
08/01/21 02:01 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
It's a lot easier for a crank to fall over and be damaged (or damage someone's foot!) if it's standing on end work
Re: Cool discussion on laying a crankshaft on it's side [Re: 340Cuda] #2949424
08/01/21 03:27 PM
08/01/21 03:27 PM
AndyF Offline
AndyF  Offline
I don't need anyone to tell me that storing a crankshaft on its side is fine, I can figure that out by just looking at it. The mains are 3 inches thick and just a few inches long. A steel bar that size cannot be bent by a few pounds of load. The topic is silly but it pops up on a regular basis.
Re: Cool discussion on laying a crankshaft on it's side [Re: AndyF] #2949448
08/01/21 04:23 PM
08/01/21 04:23 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Always was amused by this. In theory just flip it like a burger and let it sit for the same amount of time on the other side to straighten it.
I wonder if I built crank storage rotisseries, would they sell? laugh
Re: Cool discussion on laying a crankshaft on it's side [Re: INTMD8] #2949527
08/01/21 08:36 PM
08/01/21 08:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Don't forget about not setting batteries on concrete as it will drain them because earth is ground whistling stirthepot
Re: Cool discussion on laying a crankshaft on it's side [Re: TJP] #2949540
08/01/21 09:07 PM
08/01/21 09:07 PM
N
NITROUSN Offline
NITROUSN  Offline
N
There is some truth to that. Not so much as the earth is ground but concrete generally has a dampness. Supposedly a battery that is wet from the dampness allows a conductivity between the posts causing a minuscule draw.
Re: Cool discussion on laying a crankshaft on it's side [Re: NITROUSN] #2949560
08/01/21 10:24 PM
08/01/21 10:24 PM
AndyF Offline
AndyF  Offline
That was true back in the old days when batteries didn't have plastic cases.
Re: Cool discussion on laying a crankshaft on it's side [Re: AndyF] #2949579
08/02/21 01:31 AM
08/02/21 01:31 AM
Maryland
MoparMike1974 Offline
Maryland
What were the cases made out of? I know of rubber and possibly bakelite. Both just as good or better insulator as plastic.
The biggest threat when storing a crank is rust and damage from getting knocked around. I spray mine with cosmoline and made storage crates. Of couse this is only ones im putting in long term storage.
Re: Cool discussion on laying a crankshaft on it's side [Re: AndyF] #2949615
08/02/21 09:31 AM
08/02/21 09:31 AM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
iagree
Re: Cool discussion on laying a crankshaft on it's side [Re: DaveRS23] #2949776
08/02/21 06:57 PM
08/02/21 06:57 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
iagree
Also implying that damp concrete is a more attractive conductor than a steel tray the battery sits on in the car for its intended life that is directly connected to the battery's negative terminal? eyes
I think the recalled "theory" above is inaccurate, concrete was implicated most often when charging a battery, and the correct issue there is, the heavier than air moist sulfuric fumes from the charging process corroded the nearby concrete, had nothing to do with the battery.
And I store my cranks on a rotisserie grin.
Re: Cool discussion on laying a crankshaft on it's side [Re: MoparMike1974] #2949791
08/02/21 07:44 PM
08/02/21 07:44 PM
AndyF Offline
AndyF  Offline
Early batteries were fairly crude. The model T used wood cases for some electrical devices. Tar was used, maybe bakelite. I'm not an expert on early battery design but it wasn't a good idea to store them on a cold, damp concrete pad back in the day. I don't think there is any issue storing a modern battery on a concrete floor but I never do it. If I have a spare battery I keep it on a wood shelf.
Re: Cool discussion on laying a crankshaft on it's side [Re: AndyF] #2949894
08/03/21 04:03 AM
08/03/21 04:03 AM
SoCal
Frank Cannon Offline
SoCal
Who owns this site?
YB has gone downhill since Monty sold it.
CALIFORNIA-SUNDAY-10:04 A.M.
Re: Cool discussion on laying a crankshaft on it's side [Re: Frank Cannon] #2949917
08/03/21 08:20 AM
08/03/21 08:20 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Absolutely.
Re: Cool discussion on laying a crankshaft on it's side [Re: Kern Dog] #2949926
08/03/21 08:44 AM
08/03/21 08:44 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Hmm. My crankshafts must be longer then. I have a crank rack that they hang from the flange. So maybe my flange is warped though. They don’t fall over though.
Re: Cool discussion on laying a crankshaft on it's side [Re: AndyF] #2949981
08/03/21 11:59 AM
08/03/21 11:59 AM
GMP440 Offline
GMP440  Offline
This topic totally went off topic. Well back to the topic. So, either standing the crank up or lying down is ok then.
Re: Cool discussion on laying a crankshaft on it's side [Re: GMP440] #2950001
08/03/21 01:32 PM
08/03/21 01:32 PM
moparx Online content
moparx  Online Content
yes..................... biggrin
beer
Re: Cool discussion on laying a crankshaft on it's side [Re: GMP440] #2950119
08/03/21 07:04 PM
08/03/21 07:04 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
laugh2 It did on the 'bullet, too which is why I posted it. There is no new information in that thread or this one. It is just interesting to see where the conversations go.
