383 intake pan gasket #2949541
08/01/21 09:08 PM
08/01/21 09:08 PM
Richmond Ohio
alexdodge2 Offline OP
Richmond Ohio
Been trying to find a intake manifold pan gasket for a 383.. its the one made by felpro with the ports not punched out for the heat passage Anyone know if its still being made or a part #? If not is there
any other way to block the heat from going under the carb? Thanks, Alex
Re: 383 intake pan gasket [Re: alexdodge2] #2949547
08/01/21 09:29 PM
08/01/21 09:29 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Re: 383 intake pan gasket [Re: NITROUSN] #2949552
08/01/21 09:51 PM
08/01/21 09:51 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Rockauto has them for $13 less.
Felpro 1214
Re: 383 intake pan gasket [Re: Sniper] #2949693
08/02/21 01:27 PM
08/02/21 01:27 PM
Richmond Ohio
Richmond Ohio
Found it thanks guys
