Re: Found 1969 4 Speed RS23L9A166042
[Re: 6bblgt]
#2904865
04/01/21 10:34 AM
04/01/21 10:34 AM
Posts: 15,995 RI Deep in the rust belt
chargervert
The engine has been rebuilt, has 0.30 pistons in it, so it is hard to tell if it came from a U code or V code car.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: chargervert]
#2907261
04/06/21 12:24 PM
04/06/21 12:24 PM
chargervert
I dug out an 18 spline Hemi 4 speed transmission from my transmission stash today. I am going to ask my transmission guy if he thinks he can rebuild it. I checked the VIN numbers on it,and I figured that I would post them on here to see if the car still exists. The VIN numbers are 0A230002 . If you have the car it came from, send me a pm here on Moparts, thanks Pete. My transmission guy took the transmission all apart and cleaned up the parts, he glass beaded the case, and ran taps through all the bolt holes. I found the side cover with the shift forks,and a whole other transmission in parts to make it complete. This will be available to the owner of the matching numbers car up to the point that I install it into a car. Once it is installed, it's staying in the car.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
1970 Hemi Cuda 727 Transmission
[Re: Alaskan_TA]
#2932786
06/13/21 12:16 PM
06/13/21 12:16 PM
Posts: 992 California
cudagee
California
I am looking for my 70 Hemi Cuda 727 transmission Originally from British Columbia Canada
BS23R0B146394
wild71cuda@aol.com
Looking for 440 block and trans
[Re: Alaskan_TA]
#2935290
06/21/21 01:16 PM
06/21/21 01:16 PM
Posts: 77 FL
moparwizard
FL
Looking for 1970 440 block and auto trans 0A155801
UPDATE BLOCK FOUND still looking for auto trans last seen in Arkansas 1980's
Re: Wanted 9A272901
[Re: chargervert]
#2941981
07/11/21 10:07 AM
07/11/21 10:07 AM
Posts: 3,068 Michigan
A727Tflite
Looking for my engine and manual trans for 9A272901.
Engine believed to be in the Northeast U.S. in a 1970 Red GTX 4 speed with AirGrabber, black interior. Lived in Tennessee and Michigan before going to the NE.
The manual trans was last known to be in a 1968 Hemi RoadRunner, Metallic Bronze when sold by the owner around 1972 to a fellow that worked at the Chrysler Chelsea Proving Grounds. I owned a red 70 GTX 440 4 speed air grabber car,with a black interior,but it had a 66 440 engine in the car! There can't be to many of them that fit the description! Well in talking to people, if the owner of the car knows someone is looking for the engine or trans - he is either holding out for some reason, doesn’t want to go through the hassle of removing it, or thinks it may be stolen and he will get in some trouble. I have heard all kinds of stuff as of late. All I would like to do is reunite the engine and trans with the car more for sentimental reasons. Car is never going to be sold so I don’t care about the “added value” of it being numbers matching.
Re: Engine and Trans Lost & Found
[Re: northcoastmopar]
#2943296
07/15/21 02:03 AM
07/15/21 02:03 AM
Posts: 707 California
BigDaddy440
California
Looking for 1969 440 block and 18 spline 4speed: 9A246400
Thank you!
209-480-5080
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#2944104
07/16/21 10:17 PM
07/16/21 10:17 PM
Posts: 3,391 cheshire, ct
davesmopars
cheshire, ct
two 4 speeds found
8E163330
8G224308
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
RM27H9G182228 Found
[Re: Dartman440]
#2966097
09/21/21 05:18 PM
09/21/21 05:18 PM
Posts: 2,578 Fargo ND
moparphilll
Fargo ND
This was in a 69 charger from i think New Mexico Looks like out of a 1969 Roadrunner Convertible! moparphilll@aol.com
Re: RM27H9G182280 Found
[Re: 6bblgt]
#2973620
10/12/21 05:30 PM
10/12/21 05:30 PM
Posts: 1,152 Colorado
CuriousYella70
Colorado
Looking for original 340 and 727 from my 1971 340 Duster. To my knowledge, spent most of its life in southern Washington.
VIN: VS29H1E115200
719-339-5417
FOUND 4 speed / ebody?
[Re: CuriousYella70]
#2974059
10/13/21 06:50 PM
10/13/21 06:50 PM
Posts: 12,797 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
Was getting some rear end work done on my pickup truck and saw this in the transmission shop. I talked to the guy and he'll sell it
Trying to enjoy life!
