Re: Cool discussion on laying a crankshaft on it's side
[Re: 340Cuda]
#2949393
08/01/21 01:25 PM
08/01/21 01:25 PM
Posts: 10,549 Rittman Ohio
fourgearsavoy
Rittman Ohio
Randy Winberg who makes some of the best crankshafts in the world, told me it did not matter how a crankshaft was stored.
That is good enough for me. I went with a buddy to Callies to pick up his crank and their inventory was all laying sideways on pallets. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 340Cuda]
#2949424
08/01/21 03:27 PM
08/01/21 03:27 PM
Posts: 30,947 Oregon
AndyF
That is good enough for me. I don't need anyone to tell me that storing a crankshaft on its side is fine, I can figure that out by just looking at it. The mains are 3 inches thick and just a few inches long. A steel bar that size cannot be bent by a few pounds of load. The topic is silly but it pops up on a regular basis.
[Re: AndyF]
#2949448
08/01/21 04:23 PM
08/01/21 04:23 PM
Posts: 702 Lake Villa Il
INTMD8
Lake Villa Il
Always was amused by this. In theory just flip it like a burger and let it sit for the same amount of time on the other side to straighten it. I wonder if I built crank storage rotisseries, would they sell?
[Re: NITROUSN]
#2949560
08/01/21 10:24 PM
08/01/21 10:24 PM
AndyF
Don't forget about not setting batteries on concrete as it will drain them because earth is ground There is some truth to that. Not so much as the earth is ground but concrete generally has a dampness. Supposedly a battery that is wet from the dampness allows a conductivity between the posts causing a minuscule draw. That was true back in the old days when batteries didn't have plastic cases.
[Re: AndyF]
#2949579
08/02/21 01:31 AM
08/02/21 01:31 AM
Posts: 294 Maryland
MoparMike1974
Maryland
Don't forget about not setting batteries on concrete as it will drain them because earth is ground There is some truth to that. Not so much as the earth is ground but concrete generally has a dampness. Supposedly a battery that is wet from the dampness allows a conductivity between the posts causing a minuscule draw. That was true back in the old days when batteries didn't have plastic cases. What were the cases made out of? I know of rubber and possibly bakelite. Both just as good or better insulator as plastic. The biggest threat when storing a crank is rust and damage from getting knocked around. I spray mine with cosmoline and made storage crates. Of couse this is only ones im putting in long term storage.
[Re: AndyF]
#2949615
08/02/21 09:31 AM
08/02/21 09:31 AM
Posts: 11,890 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Master, again and still
[Re: DaveRS23]
#2949776
08/02/21 06:57 PM
08/02/21 06:57 PM
Posts: 22,695 Bitopia
jcc
Bitopia
Don't forget about not setting batteries on concrete as it will drain them because earth is ground There is some truth to that. Not so much as the earth is ground but concrete generally has a dampness. Supposedly a battery that is wet from the dampness allows a conductivity between the posts causing a minuscule draw. That was true back in the old days when batteries didn't have plastic cases. Also implying that damp concrete is a more attractive conductor than a steel tray the battery sits on in the car for its intended life that is directly connected to the battery's negative terminal? I think the recalled "theory" above is inaccurate, concrete was implicated most often when charging a battery, and the correct issue there is, the heavier than air moist sulfuric fumes from the charging process corroded the nearby concrete, had nothing to do with the battery. And I store my cranks on a rotisserie .
[Re: MoparMike1974]
#2949791
08/02/21 07:44 PM
08/02/21 07:44 PM
AndyF
Don't forget about not setting batteries on concrete as it will drain them because earth is ground There is some truth to that. Not so much as the earth is ground but concrete generally has a dampness. Supposedly a battery that is wet from the dampness allows a conductivity between the posts causing a minuscule draw. That was true back in the old days when batteries didn't have plastic cases. What were the cases made out of? I know of rubber and possibly bakelite. Both just as good or better insulator as plastic. The biggest threat when storing a crank is rust and damage from getting knocked around. I spray mine with cosmoline and made storage crates. Of couse this is only ones im putting in long term storage. Early batteries were fairly crude. The model T used wood cases for some electrical devices. Tar was used, maybe bakelite. I'm not an expert on early battery design but it wasn't a good idea to store them on a cold, damp concrete pad back in the day. I don't think there is any issue storing a modern battery on a concrete floor but I never do it. If I have a spare battery I keep it on a wood shelf.
[Re: AndyF]
#2949894
08/03/21 04:03 AM
08/03/21 04:03 AM
Posts: 393 SoCal
Frank Cannon
SoCal
Who owns this site? YB has gone downhill since Monty sold it.
CALIFORNIA-SUNDAY-10:04 A.M.
[Re: AndyF]
#2949981
08/03/21 11:59 AM
08/03/21 11:59 AM
Posts: 1,637 Florida
GMP440
This topic totally went off topic. Well back to the topic. So, either standing the crank up or lying down is ok then.
[Re: GMP440]
#2950119
08/03/21 07:04 PM
08/03/21 07:04 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
This topic totally went off topic. Well back to the topic. So, either standing the crank up or lying down is ok then. It did on the 'bullet, too which is why I posted it. There is no new information in that thread or this one. It is just interesting to see where the conversations go.
