Re: 512 build thoughts [Re: ShawnS] #2946739
07/24/21 06:45 PM
07/24/21 06:45 PM
I answer your post in the general section scope
I go there first usually shruggy
Re: 512 build thoughts [Re: ShawnS] #2946750
07/24/21 07:05 PM
07/24/21 07:05 PM
AndyF Online content
AndyF  Online Content
Originally Posted by ShawnS
Thanks. Great looking engine and car btw. Also I’ll have him call Dwayne if you think his cam may be better suited then the comp you spoke of.
Yes, tell you engine builder to call Porter Racing Heads for a cam recommendation. If I was building your engine I wouldn't use the Comp grind that I used in the past since now I know that Porter can provide me with a custom cam that will work even better for roughly the same price. I didn't understand that 10 years ago when I first started to build 600 hp street engines.
Re: 512 build thoughts [Re: AndyF] #2946767
07/24/21 07:51 PM
07/24/21 07:51 PM
Wilmington, North Carolina USA
ShawnS Offline OP
ShawnS  Offline OP
Cab I apologize I never saw it. I posted there first cause I wasn’t sure then saw the engine forum and moved it
AndyF one question I have. I believe I just found the article or your dual quad build. Also testing a single 4 intake that made more power. One thing that caught my attention was the 12.1 compression to make that 615hp. Don’t believe that will work with 93 lol. Wonder what horsepower loss would occur with just 10.5 or whatever can be run on pump gas.
Re: 512 build thoughts [Re: ShawnS] #2946794
07/24/21 09:41 PM
07/24/21 09:41 PM
That 505 had Edelbrock heads. The TF heads will make 600+ hp with pump gas compression. The 496 in my Coronet is 9.8 compression and it made more power than that high compression 505. The key is to use a flat top piston with tight quench and then put a dish in the piston to get the compression that you want. And you need the correct cam to match the heads. The 505 article was written 10 years ago and some things have changed since then.
Re: 512 build thoughts [Re: AndyF] #2946808
07/24/21 10:39 PM
07/24/21 10:39 PM
ShawnS Offline OP
ShawnS  Offline OP
Now you got me looking at these dang sniper systems trying to figure out what all is needed haha.
Re: 512 build thoughts [Re: ShawnS] #2946829
07/24/21 11:51 PM
07/24/21 11:51 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I didn’t know this was a twofer so I’ll drop this here too.
Andy,
I thought you said the terminator efi was a lot better than the sniper for only a few hundred more?
I would call Dwayne porter and let him get the heads he says will work, the 240 or the 270, then let him work them a bit and check them over. Worth it to be sure before you use as a daily driver. Let him spec the cam.
I’d be going roller or at least not a solid for a street car you are talking about driving hundreds of miles a week.
The RPM is an excellent intake, sounds like a good idea to try it and economize and then later try another intake if you want.
I’d put the savings into a milodon 31580 road race pan. It’s a superb piece and will protect your investment.
Another option since you are in NC is to just call Todd Marsh at Marsh Performance. I used him for the bottom end of my 496 and Dwayne for the heads. Had local shop do the machine work.
Good luck.
I want my fair share
Re: 512 build thoughts [Re: ShawnS] #2946840
07/25/21 12:40 AM
07/25/21 12:40 AM
If you want some Sniper info you can check out these two articles: https://www.motortrend.com/how-to/super-sniper-efi-sees-powerful-improvements-data-logging/
https://www.motortrend.com/how-to/holley-hyperspark-install-tune/
I wrote these articles when the Sniper was brand new so there is a bunch more information available now. I've installed about 20 Snipers over the past few years. They solve a bunch of problems and add a bunch of capability to a street/strip type of engine but they aren't for everyone. You need a Windows laptop and you need to be comfortable with basic computer skills to really get the most out of a Sniper. The total investment is usually around $2000 which is roughly what a new carb, ignition, fuel pump, etc would cost. Just depends on which way a person wants to go.
Re: 512 build thoughts [Re: AndyF] #2946843
07/25/21 01:35 AM
07/25/21 01:35 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I haven't priced it out for one of these engines, but considering port injection efi intakes are available why not go that route over the sniper?
(just cost difference?)
Re: 512 build thoughts [Re: INTMD8] #2946845
07/25/21 02:04 AM
07/25/21 02:04 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tf 240 head will be fine , TF270 will be better and more power . In my motor was worth 0.25 of second or about 40-50hp .
If you cant get a Super Victor max wedge you can port the standard port Super Victor to max wedge , i did that . Not sure if Victor will go max wedge
Loss of torque ? You have a 4.25 stroke 511ci motor .
Flat tappet is simple and durable , again thats what i run .
I have pump gas 11:1 premium gas .
Idles @ 925 in gear in traffic no worries , summer or winter .
Dual quad ? Try a modman , wont choke it like eddy unit , and has enough meat to go max wedge . Run 2 x eddy 600s or 800 eddy AVS
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 512 build thoughts [Re: ShawnS] #2946884
07/25/21 09:55 AM
07/25/21 09:55 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Beautiful car. Not sure how big of a hole that was cut out in your hood for the scoop but the intakes you mentioned on using are taller so might have to do more modifications there.... Give Jesse at Biggs carburetor call to discuss your plans also
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 512 build thoughts [Re: ShawnS] #2946930
07/25/21 11:27 AM
07/25/21 11:27 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Contact our own Thumperdart. He is the go-to Holley platform guy. And then compare his prices to the EFI conversion cost. Retrofit EFI simply does not bring enough advantages to warrant the huge additional costs and labor over a well tuned carb like Thumperdart can get you.
And here's another vote for Dwayne Porter for the cam.
Master, again and still
Re: 512 build thoughts [Re: 67mprfan] #2947003
07/25/21 02:37 PM
07/25/21 02:37 PM
ShawnS Offline OP
ShawnS  Offline OP
Hole in the hood is fairly large but can go bigger if needed.
Re: 512 build thoughts [Re: ShawnS] #2947089
07/25/21 07:35 PM
07/25/21 07:35 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Okay so no problem going with a taller intake I do have a super victor I'll let go for a reasonable price if interested
Re: 512 build thoughts [Re: 67mprfan] #2947112
07/25/21 08:25 PM
07/25/21 08:25 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Will running short pistons for the 4.25 with 7.1 rods make for wear and oil consumption issues on a daily driver?
Re: 512 build thoughts [Re: SomeCarGuy] #2947118
07/25/21 08:40 PM
07/25/21 08:40 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
doesnt seem to worry mine
Tex
New best MPH 130.32
Re: 512 build thoughts [Re: SomeCarGuy] #2947182
07/25/21 11:31 PM
07/25/21 11:31 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
No issues here.
'63 Dodge 330
11.19 @ 121 mph
Re: 512 build thoughts [Re: GY3] #2947187
07/25/21 11:54 PM
07/25/21 11:54 PM
No issues here.
iagree
I've got several (10 to 15) 440 pump gas motors with those parts in them with no complaints on oil consumption yet shruggy
I ran a 4.300 stroke crank in my pump gas 400 stroker motor with 7.800 long BB Chevy type rods that had a VERY SHORT piston in it and it didn't use oil on the street or at the track boogie
Many interweb rumors have to basis for them, in my opinion shruggy
Re: 512 build thoughts [Re: SomeCarGuy] #2948112
07/28/21 11:33 AM
07/28/21 11:33 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
To delve a little deeper on this,On an RB, the rod ratio is only 1.67 and side load is 361 psi.
A stock 5.3 LS for example is 368 psi and 1.68 rod ratio.
'63 Dodge 330
11.19 @ 121 mph
