Re: cam tech
[Re: mopar dave]
#2947110
07/25/21 08:20 PM
07/25/21 08:20 PM
Posts: 6,135 Melbourne , Australia
LA360
Billy Godbold has done a few of late with various webinars and podcasts. Some of it it talking about Comp stuff specifically, but there is some interesting info regardless
Alan Jones
Re: cam tech
[Re: mopar dave]
#2947491
07/26/21 07:27 PM
07/26/21 07:27 PM
Posts: 4,205 New York
polyspheric
New York
Far too many cam explanations leave out 2 factors (1 big, one small): 1. combustion chamber design (shape, volume, stem angle); wedge cam and hemi cam = chalk & cheese 2. rod ratio
Boffin Emeritus
Re: cam tech
[Re: polyspheric]
#2947830
07/27/21 03:29 PM
07/27/21 03:29 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Far too many cam explanations leave out 2 factors (1 big, one small): 1. combustion chamber design (shape, volume, stem angle); wedge cam and hemi cam = chalk & cheese 2. rod ratio If a hemi and wedge somehow ended up with identical flow numbers (hypothetically obviously), compression, displacement... how would you change cam specs based on the chamber and valve arrangement? What change would you do to a cam if everything was identical but one had much shorter rod stroke ratio?
Re: cam tech
[Re: HotRodDave]
#2948051
07/28/21 09:27 AM
07/28/21 09:27 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
What change would you do to a cam if everything was identical but one had much shorter rod stroke ratio? Are we betting on whether the answer to this question is ignored or deflected?
Re: cam tech
[Re: HotRodDave]
#2948096
07/28/21 11:10 AM
07/28/21 11:10 AM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
Far too many cam explanations leave out 2 factors (1 big, one small): 1. combustion chamber design (shape, volume, stem angle); wedge cam and hemi cam = chalk & cheese 2. rod ratio If a hemi and wedge somehow ended up with identical flow numbers (hypothetically obviously), compression, displacement... how would you change cam specs based on the chamber and valve arrangement? What change would you do to a cam if everything was identical but one had much shorter rod stroke ratio? Go ask on speed-talk.com. There are a few very knowledgeable cam grinders, engine builders, and class racers who regularly get into cam debates. I wish Harold was still around. He was the man. I think Vizard may have addressed some of this in his books.
