Exhaust system.... #2946876
07/25/21 09:34 AM
07/25/21 09:34 AM
sweden
carter Offline OP
carter  Offline OP
sweden
I have 1 7/8" headers and full 3" exhaust system, both from TTI on my 512. I'm little curios howe much HP it can support....
Howe fast have you gays bin with your street car and a full 3" system...... Yes, all the way to your bumper.
Re: Exhaust system.... [Re: carter] #2946879
07/25/21 09:47 AM
07/25/21 09:47 AM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I have 2 1/8 TTI's with 3.5" collector and 3" to the bumper and been 10.90s in my 528. Really mild hemi. Nice and quiet too.
Re: Exhaust system.... [Re: Uncle Barry] #2946897
07/25/21 10:13 AM
07/25/21 10:13 AM
sweden
carter Offline OP
carter  Offline OP
sweden
Thats my goal 6.9 / 10.9s ..... Well done.. up
Re: Exhaust system.... [Re: carter] #2946917
07/25/21 10:54 AM
07/25/21 10:54 AM
UK
rb446 Offline
rb446  Offline
UK
Not too similar to your combo but we have been a best of 10.35@130 with our 3800lb '69RR, 2.1/8" TTI's, 4" collectors and only 2.1/2" pipes to the bumper...motor is a mild 10:1CR 589ci wedge, dyno'd@695hp, track hp with mechanical w/pump/alternator full exhaust, we lost approx 20hp
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Exhaust system.... [Re: carter] #2946928
07/25/21 11:14 AM
07/25/21 11:14 AM
U
Uncle Barry Offline
Uncle Barry  Offline
U
https://youtu.be/Njgx1qtgu1E
Re: Exhaust system.... [Re: carter] #2946998
07/25/21 02:22 PM
07/25/21 02:22 PM
My old pump gas duster ran a set of Headman fender well A body headers with 2.0 primary pipes with 3.5 inch collectors going into a 3.0 inch system to the Magnaflow 14x7 oval muffs mounted behind the rear end, it went 9.993 at 134.8 MPH on Oregon pump swill with the air cleaner and exhaust system on using 91 octane Oregon pump swill boogie
It weighed 3450 lbs. with me in the car shruggy
I did remove the pipes and muffs from the collector back at our local 1/8 mile track and it pick up from 7.01 to 6.98 ET and .2 MPH, not worth taking it off twocents realcrazy shruggy
Re: Exhaust system.... [Re: Cab_Burge] #2947041
07/25/21 04:36 PM
07/25/21 04:36 PM
sweden
carter Offline OP
carter  Offline OP
sweden
So your exhaust system don't hold you back, a real test up
Re: Exhaust system.... [Re: carter] #2947093
07/25/21 07:50 PM
07/25/21 07:50 PM
no mans land
racerbychoice Offline
no mans land
What kind of car is it going on? Any pics to share?
Re: Exhaust system.... [Re: racerbychoice] #2947179
07/25/21 11:27 PM
07/25/21 11:27 PM
sweden
carter Offline OP
carter  Offline OP
sweden
If it`s me you mean?
It`s my street car that I take to a track once or twice a year. I don't know if I have enough power to go 6.9x in a 1/8 track. It weight 3860 lbs with me in and best is 7.19 and 98.3 MPH... 60 feet is typisch 1.65-70
Re: Exhaust system.... [Re: carter] #2947186
07/25/21 11:49 PM
07/25/21 11:49 PM
Focus on making it 60 ft. better first wrench twocents.
.02 increase in the 60 will make it go .05 to .07 better in the 1/8 and 1/4 mile depending on your motor and shift points scope up
Re: Exhaust system.... [Re: Cab_Burge] #2947651
07/27/21 04:10 AM
07/27/21 04:10 AM
sweden
carter Offline OP
carter  Offline OP
sweden
My home track has a lot of No Prep events ( Yes! it is crap) so there is no bite at all. I have order a set of DA shocks up front and 1" taller rear tires so I maybe slow it down a little in 60 feet. I guess I don't gona see a much diffrence in 60 feet, but I run out of ideas shruggy
Is my 98,3 MPH enough to go a 6,9x on a 1/8 track?
Re: Exhaust system.... [Re: carter] #2947655
07/27/21 05:24 AM
07/27/21 05:24 AM
UK
rb446 Offline
rb446  Offline
UK
@3860 what your trying to achieve would look like this with a hook>
Power to Weight Ratio: 0.15 : 1 (HP per 1 Pound Weight)
60 Foot E.T. : 1.53 Seconds
1/8 Mile E.T. : 6.93 Seconds
1/8 Mile Trap Speed : 98.10 MPH
1/4 Mile E.T. : 10.98 Seconds
as said your 60ft needs a lot of work and with what looks to me like street tyres? it ain't happening, hp is there in the mph.
Re: Exhaust system.... [Re: rb446] #2947731
07/27/21 10:46 AM
07/27/21 10:46 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My Cuda in full "Street" trim, goes 9.89 at 134mph....I run Hooker headers 2.25 tubes to 3.5" collectors shrunk down to 3" exhaust and 3" flow masters....No x pipe....
60ft is a 1.33 so far....on DOT "tires"...
Take the mufflers and exhaust off and open it to 3.5" wide open....Same ET.
Re: Exhaust system.... [Re: Dragula] #2947801
07/27/21 01:52 PM
07/27/21 01:52 PM
moparx Offline
moparx  Offline
would there be any gain if the 3 1/2" collector size used around 18-20" of 3 1/2" pipe before necking down to 3" at the X or H pipe, then 3" the rest of the way ?
think collector extensions. shruggy
beer
Re: Exhaust system.... [Re: rb446] #2947818
07/27/21 02:38 PM
07/27/21 02:38 PM
sweden
carter Offline OP
carter  Offline OP
sweden
I guess a 60ft in 1.55 range is possible on a good / prep track. Tyres is now Hoosier QTP 28" tall. Yes! I have to work with 60ft if this should be true wrench
Re: Exhaust system.... [Re: Dragula] #2947821
07/27/21 02:47 PM
07/27/21 02:47 PM
sweden
carter Offline OP
carter  Offline OP
sweden
It seems that a full 3" exhaust is capable to support big motors and HP, so I don't have to worry about that.... grin
Re: Exhaust system.... [Re: carter] #2947843
07/27/21 04:21 PM
07/27/21 04:21 PM
Dragula Offline
Dragula  Offline
I think the muffler matters more than going to bigger than 3"...Personally, the best sounding and best performance mufflers I like are the Spintech ones with their oval exhaust. Get the best of both worlds...
Re: Exhaust system.... [Re: Dragula] #2948021
07/28/21 08:15 AM
07/28/21 08:15 AM
an8sec70cuda Offline
That is surprising. Mine doesn't seem to like mufflers...atleast not much of one. Runs best w/ 4" race Bullets right off the collectors. My headers have 4" collectors though. Open headers runs about the same, but the 60 foot is slightly softer.
My H pipe system is really heavy though, so I'm sure part of the gain is from weight loss.
CHIP
'06 GMC 2500HD LBZ Duramax
