Rocker arm hardware
#2945830
07/21/21 09:58 PM
07/21/21 09:58 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
Broke an adjuster today and I was looking at Smith Brothers to replace them are they the best? Thanks Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Rocker arm hardware
[Re: fourgearsavoy]
#2945833
07/21/21 10:03 PM
07/21/21 10:03 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
Broke an adjuster today and I was looking at Smith Brothers to replace them are they the best? Thanks Gus Hell no Buy the race Manton with their lock nuts (951-245-6565) and never look back Not cheap though
[Re: fourgearsavoy]
#2951961
08/09/21 08:36 AM
08/09/21 08:36 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I have Manton adjusters in my hemi. No issues ever and they're great to deal with.
[Re: an8sec70cuda]
#2951972
08/09/21 09:39 AM
08/09/21 09:39 AM
Posts: 9,098 Rogue River, OR
Jeremiah
Rogue River, OR
For $100 adjusters I can Smith Bros. For $200 adjusters I call Trend or Manton. The adjusters are usually $160-170 and add another Andrew for nuts.
My Flat tappet stuff gets Smith.
[Re: an8sec70cuda]
#2952033
08/09/21 12:20 PM
08/09/21 12:20 PM
Posts: 2,102 Byron, NY
W.I.N. Racing
Byron, NY
Same here, part number 824 has a thru hole which eliminated a lubrication issue I had caulsing gauling adjusters adn Push Rod Cups
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2952040
08/09/21 01:01 PM
08/09/21 01:01 PM
Posts: 201 Texas
Chief
Texas
Same here, part number 824 has a thru hole which eliminated a lubrication issue I had caulsing gauling adjusters adn Push Rod Cups Question.. Do you pull valve covers and check after every pass? How often do you check? This is something that has been bugging me for a while and has kept me from completing my hemi build. Dave
Dave Covey
[Re: Cab_Burge]
#2952196
08/09/21 08:47 PM
08/09/21 08:47 PM
fourgearsavoy
Rittman Ohio
Well I'm going with the Smith Bros. adjusters. My current springs are only 365# open with a mild SFT so I think they should do the job. I don't know what adjusters RAS uses on their rockers but in changing all of them. A good buddy(10 second GTX) gave an old Crane adjuster to get me through the weekend at Norwalk Gus
[Re: Chief]
#2952428
08/10/21 12:22 PM
08/10/21 12:22 PM
W.I.N. Racing
Byron, NY
Same here, part number 824 has a thru hole which eliminated a lubrication issue I had caulsing gauling adjusters adn Push Rod Cups Question.. Do you pull valve covers and check after every pass? How often do you check? This is something that has been bugging me for a while and has kept me from completing my hemi build. Dave I was only checking once twice an event, but for other reasons I am now checking every pass. Not necessarily for push rod issues but all things valvtrain related
[Re: W.I.N. Racing]
#2955874
08/21/21 12:39 AM
08/21/21 12:39 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
I run Smith Brother’s and never had any issue and real happy with there service.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
