Mopar Differential For Sale - 3rd Quarter #2939363
07/03/21 01:05 PM
07/03/21 01:05 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2939468
07/03/21 03:31 PM
07/03/21 03:31 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
Moser 35 spline spool for a 8 ¾ I would rather not ship this. I can deliver it to Chrysler’s at Carlisle, or you can pick it up in Connecticut. $125
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2939617
07/03/21 09:40 PM
07/03/21 09:40 PM
MI
6PAX Online content
6PAX  Online Content
MI
Dana 60 3:54 ring and pinion. $125
I also have a couple of stock 8 3/4 pinion snubbers. $25 each.
gt340 @ yahoo.com
Dana gears.JPG (572 downloads)
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2939752
07/04/21 11:07 AM
07/04/21 11:07 AM
Edison, NJ 08817
budman1965 Offline
budman1965  Offline
Edison, NJ 08817
8 3/4 center section-742 case open with 2.76 gears and small yoke. Ready to bolt in and use as is or change gears and add posi unit. Will be at Mopars at Carlisle spaces L99-100. Contact Bud: Kramden426 at aol.com Sold
1970 B-Body 4.10 DANA 60 from Calif. $2400. [Re: budman1965] #2940248
07/05/21 07:20 PM
07/05/21 07:20 PM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
This is a real clean never opened 4.10 Dana 60 Super Track Pack rear end with power disc brakes 10" rear drums. All original 4.10 and lub tags. Super clean rust free housing complete with yoke caps no snubber. 9/22/9 date code. Can deliver to Carlisle for free. Car corral spot CA234 . $2400.
Re: 1970 B-Body 4.10 DANA 60 from Calif. $2400. [Re: Dartman440] #2945635
07/21/21 02:09 PM
07/21/21 02:09 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
USED,RECONDITIONED ARMASTEEL ,COARSE,SMALL UJOINT 8 3/4 YOLK, BLASTED/PAINTED,POLISHED, NORS STRAPS,BOLTS,WASHER&NUT $65 MAILED
cowgerwilliam035@gmail.com
ARMASTEEL 001.JPG (261 downloads)
ARMASTEEL 002.JPG (262 downloads)
ARMASTEEL 003.JPG (261 downloads)
ARMASTEEL 004.JPG (261 downloads)
Re: 1970 B-Body 4.10 DANA 60 from Calif. $2400. [Re: Joesixpack] #2945642
07/21/21 02:16 PM
07/21/21 02:16 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
USED,FINE SPLINE,SMALL UJOINT 8 3/4 YOLK, HAS GROOVE WILL NEED A SPEEDI SLEEVE, BLASTED/PAINTED.NORS STRAPS,BOLTS,NUT&WASHER,$50 MAILED
finw 001.JPG (259 downloads)
finw 002.JPG (259 downloads)
finw 003.JPG (258 downloads)
finw 004.JPG (257 downloads)
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2945740
07/21/21 06:59 PM
07/21/21 06:59 PM
Pa
Hemihead2 Offline
Hemihead2  Offline
Pa
8 3/4” 3.73 ratio Sure-grip Center section. 489 case with aftermarket R/P, new bearings and seal with 7290 (Big) yoke. Ready to install. Pick-up preferred-will ship to you from Pa for cost. $850 firm. Please PM here if interested. Thanks
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2945956
07/22/21 10:10 AM
07/22/21 10:10 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Used 8 3/4 axle lock $10 mailed to you.
axle lock.jpg (198 downloads)
Re: Mopar Differential For Sale - 3rd Quarter [Re: mopars4ever] #2945968
07/22/21 10:34 AM
07/22/21 10:34 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
8 3/4 used straps&bolts, 2 sets for the small ujoint, 1 strap for the large ujoint. $25 mailed for all
834strap 001.JPG (195 downloads)
834strap 002.JPG (195 downloads)
834strap 003.JPG (196 downloads)
834strap 004.JPG (196 downloads)
Re: Mopar Differential For Sale - 3rd Quarter [Re: Joesixpack] #2946316
07/23/21 11:15 AM
07/23/21 11:15 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NOS MADE IN THE USA TIMKEN DIFFERENTIAL BEARING SET LM 501349/LM501310 NOW SET#45 WILL FIT;
1987-1988-1989 DAKOTA 7 1/4
1966-1969 8.25 REAR AXLE B-BODY
1963-1975 A-BODY 7 1/4
1968-1969 8.25 A-BODY
1980-1983 7 1/4 CHRYSLER$20.00 PLUS 8.00 PRIORITY MAIL SMALL FLAT RATE BOX
Re: Mopar Differential For Sale - 3rd Quarter [Re: Joesixpack] #2946318
07/23/21 11:17 AM
07/23/21 11:17 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NOS 2881041 PINION SEALS, 2, WILL FIT 8 1/4 REAR AXLE 1969-1976, both have # and a pentastar on them$20
MAILED TO YOU FOR FREE
Re: Mopar Differential For Sale - 3rd Quarter [Re: Joesixpack] #2946320
07/23/21 11:20 AM
07/23/21 11:20 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
4 NOS 2404121 PINION SEAL, 3 BOXES ,1 LOOSE, FIT 741 CASE 8 3/4 The original OEM number is 1738831 and 2404121. Seal dimensions are: 1.875 X 2.813/2.817 X.500, the OD of the flange is 2-15/16". It is for a 1-3/8" dia. stem with a shaft dia. of 1-7/8" and a housing bore of 2.813". Make sure your original seal matches these dimensions$30 mailed
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2946575
07/24/21 10:20 AM
07/24/21 10:20 AM
Locomotion Offline
Locomotion  Offline
NEW Moser Dana 60 - A-Body Mopar width.
* Housing width - 52"
* Axle (drum) flange-to-flange - approx. 56.25"
* 35 spline steel spool
* 35 spline axles
- PRO flange
- 5/8" x 2" screw-in studs
- For E/B body drum brakes
- 5 x 4.5" bolt pattern
* 4.88 PRO/Comp gears
- Lightened ring gear
- Micro-polished ring & pinion
- Forged 1350 yoke w/u-bolts
* Aluminum Performance Girdle/Cover
* Adjustable pinion snubber
* Spring pads & axle flange housing studs included but not installed.
* Some parts have a little surface rust, as visible in photos.
* More photos available.
$2,400.00 No waiting (Regular cost to duplicate almost $3,000.00)
* Unable to crate/ship at this time. Available for p/u near Bunnell, Florida 32110 - less than 1/2 hour north of Daytona.
* Sorry, no PayPal
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2946889
07/25/21 10:04 AM
07/25/21 10:04 AM
md
mopars4ever Offline
mopars4ever  Offline
md
NOS P4529701 8 3/4 crush sleeve pkg. $30 plus $7 shipping.
1967-72 A body 8.75 rear end 3.23 NON sure grip [Re: moparts] #2947219
07/26/21 07:33 AM
07/26/21 07:33 AM
NH USA
littleredcoffin Offline
NH USA
Has 3.23 NON sure grip gearing. Large yoke.3.23 tag is still on the rear end. It`s getting tougher to find these and with the big yoke this is even a better find.$675 firm. My price will not be beaten. Located in NEW HAMPSHIRE.. Calls only 603 209 1678
