Re: Removal trick plastic “rivets” on plastic splash shields?
[Re: 360view]
#2945686
07/21/21 04:17 PM
07/21/21 04:17 PM
Posts: 15,900 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I just take a real thin flat head screw driver and wiggle the top pin up enough to pull all the way up with needle nose pliers and then I wiggle the base out with larger flat head and pliers for the one type and the other type just a big flathead and I wiggle it up all around the base and needle nose pliers after I work it out some.
Facts are stubborn things.
[Re: larrymopar360]
#2945687
07/21/21 04:22 PM
07/21/21 04:22 PM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
if its the actual rivet style (mandrel) you can push the center out with a pin punch and they will fall out
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#2945701
07/21/21 04:45 PM
07/21/21 04:45 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
if its the actual rivet style (mandrel) you can push the center out with a pin punch and they will fall out You have to be able to get to the underside to push it out and you can't always do that. I just replaced headlight assemblies on a 2010 Charger and there are a bunch of both types and the underside are not accessible.
[Re: larrymopar360]
#2945703
07/21/21 04:55 PM
07/21/21 04:55 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
In the past I have always just snipped them off with electrical side cutter pliers, and then bought new ones, but I thought: “maybe there is a slick trick to remove them and then re-use them.” Side cutters are the easiest way I've found but I don't use them to cut the rivet. The side cutters will get under the head fairly easily. Then you just twist the side cutters side to side and the rivets usually pop out. I'm talking about the solid type...not the ones with the extra center piece that pops up.
[Re: 360view]
#2945801
07/21/21 08:48 PM
07/21/21 08:48 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
[Re: IMGTX]
#2945920
07/22/21 08:07 AM
07/22/21 08:07 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
i am a certified autobody tech. i install thousands of fasteners monthly.
plastic rivets are NOT REUSABLE. you have to replace with another rivet or a comparable push in fastener. they use a special rivet gun to install. a lot of times the inner plastic pin breaks when installing. they are somewhat a pain in the rear to install sometimes. so most times i just cut and replace with a push in fastener when i can.
the plastic push in fasteners, like the "christmass tree" earlier pic of one, are rather difficult to remove and reinstall without damaging the part they are attached to. they twist the fender tabs holding them in when you try to save them. on them pushed into a solid part i use a bent end long nose pliers and pull them out. on fenders i just cut with a side cutters and replace.
the push pin fasteners are easy to remove and replace. just pull the inner pin out with a side cutters or comparable tool and the outer pin usually falls out. sometimes a bent end pick works great to remove the inner pin.
in most body shops have a bin with extra fasteners. i just go into the bin and find another comparable sized one for a replacement part.
perception is 90% of reality
[Re: IMGTX]
#2946008
07/22/21 12:22 PM
07/22/21 12:22 PM
Posts: 19,479 north of coder
moparx
i have, and use, a multitude of different tools to remove those retainers. some home made, and others like shown above. i also have a couple of boxes of different types of retainers on hand to replace as needed. some of those can be a real pain to remove, even with the use of tools.
