Re: Engine bolt finish?
[Re: mopar4ya]
#2944497
07/18/21 09:55 AM
07/18/21 09:55 AM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
yes
but then engine color
EDIT, excluding motor mount bolts, clutch fan bolts, = clear zinc
[Re: mopar4ya]
#2944732
07/19/21 12:49 AM
07/19/21 12:49 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Can't speak for big block, but on my 1969 340, a few engine fasteners are zinc plated. For example, the 12 intake manifold to head fasteners are yellow zinc then engine painted.
Probably the reason for yellow zinc fasteners in the intake manifold is because the coil is attached to it and grounded to it.
Fasteners for head to firewall ground and negative battery cable to head are also yellow zinc then painted engine color on my 340.
