Re: 4 speed 833 question
[Re: fastmark]
#2943116
07/14/21 03:07 PM
07/14/21 03:07 PM
Posts: 4,457 Washington
madscientist
Washington
I’ve got a question about the synchros between 69 down and the 70 up. They changed in 70 for a “ better” design. Is it that much better? I’ve built all years but only owned and driven 70 up style for many years. Is it worth upgrading from the 69 style on this next rebuild? Brewers has a complete assembly for pretty a reasonable price. I’m try to advice a couple of customers on the upgrade. P Absolutely not. If you want to “upgrade” it, you need the later hubs and struts. Everything else is the same. I have both, use both and there is ZERO difference in shifting or anything else. If the early struts you have are worn out they are easily replaced. Upgrading is a waste of time and money IMO.
[Re: fastmark]
#2943176
07/14/21 06:03 PM
07/14/21 06:03 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Mopar had NP make three different synchro assembly in their trannies, 1964 to maybe mid 1966 or mid 1967, and then upgraded them some. The 1970 and later, wider synchro types work okay as far as I'm concern, no better than the second generations synchros as long as you have the clutch pedal linkage adjusted properly
[Re: madscientist]
#2943242
07/14/21 08:58 PM
07/14/21 08:58 PM
Posts: 1,327 VA
dragon slayer
VA
I’ve got a question about the synchros between 69 down and the 70 up. They changed in 70 for a “ better” design. Is it that much better? I’ve built all years but only owned and driven 70 up style for many years. Is it worth upgrading from the 69 style on this next rebuild? Brewers has a complete assembly for pretty a reasonable price. I’m try to advice a couple of customers on the upgrade. P Absolutely not. If you want to “upgrade” it, you need the later hubs and struts. Everything else is the same. I have both, use both and there is ZERO difference in shifting or anything else. If the early struts you have are worn out they are easily replaced. Upgrading is a waste of time and money IMO. Just to be clear, the syncro, hub, slider, strut and spring are different. Swapped as a set. If you look closely there is a difference in the strut height, and therefor the slider is different too. Internal cut.
[Re: fastmark]
#2944090
07/16/21 09:23 PM
07/16/21 09:23 PM
Posts: 704 USA
rftroy
USA
The later synchros are substantially better. There is a reason that the company spent all the money to redesign and supercede the parts. It's not a question of how well they work or shift, it's a durability issue.
I have personally had two cases of early brass synchro ring failure over the years in my cars. The notch that locates the ring in the synchronizer hub and keeps it from rotating is square and has sharp corners, ideal for stress concentration and cracking. The crack starts at the bottom of the notch and cracks through the entire ring, making a gap that lets the ring open up and provide zero clamping force against the gear clutch cone. The later synchro rings have a notch that has a large radius curve to significantly reduce the stress in the brass ring.
Either type of shychro will shift the same way, when they are working. Once the earlier style cracks, it will stop shychronizing and you will grind gears unless you learn to match speeds when shifting.
I would personally not consider using the pre-1970 shychronizers.
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#2945460
07/21/21 06:54 AM
07/21/21 06:54 AM
Posts: 6,416 Abilene, Texas
fastmark
Abilene, Texas
Robert Thanks Robert. That’s kinds of the answer I was looking for. I’ve rebuilt both and the 70 up sure looked like a better design to me. I did talk to Wayne Brewer and his opinion was if all the parts of the 69 were in good condition, they would be just fine. I tend to agree if all they parts are in good condition. However, both of these customers are good friends and want really good transmissions and cost the additional cost is not a factor. One is going behind a 650 hp hemi. Both are going to use the gear vendor overdrives.
