5.9 magnum cam sensor #2942111
07/11/21 06:11 PM
07/11/21 06:11 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
How does it work? Is it a simple on/off once every time the distributor makes a 360 rotation? Would it work the same if rotated counter clockwise?
Re: 5.9 magnum cam sensor [Re: mgoblue9798] #2945105
07/20/21 11:05 AM
07/20/21 11:05 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
It's a hall effect sensor that sends a square wave signal to the ecu. It would not know or care which direction the distributor vane is being rotated.
Re: 5.9 magnum cam sensor [Re: DaytonaTurbo] #2945177
07/20/21 12:52 PM
07/20/21 12:52 PM
Atlanta, GA
Atlanta, GA
Thank you very much sir.
