6.4 bge engine with 6.4 srt intake #2941890
07/10/21 07:28 PM
07/10/21 07:28 PM
Lapeer, MI.
todd440 Offline OP
todd440  Offline OP
Lapeer, MI.
Using a 6.4 bge as a transplant into a b-body, and not wanting to use the BGE intake due to the TB upward angle, can't I use a srt 6.4 intake instead? Seems like it would be a bolt on.
Re: 6.4 bge engine with 6.4 srt intake [Re: todd440] #2941937
07/10/21 11:13 PM
07/10/21 11:13 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Are you talking 6.4 truck vs 6.4 Passenger ? if so yes all BGE & Apache heads have the same intake port dimensions and bolt pattern, the Hellcat(and Demon) have a different bolt pattern ....same port shape and size .
the TB is on the left on the truck Manifold, and the TB is on the right on the SRT(passnegercar) the Eagle Passenger car Manifold puts the TB in the center like a 6.1 and Eddelbrock Victor.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 6.4 bge engine with 6.4 srt intake [Re: ric3xrt] #2941977
07/11/21 09:47 AM
07/11/21 09:47 AM
Lapeer, MI.
todd440 Offline OP
todd440  Offline OP
Lapeer, MI.
Thanks for the reply. Yes, that's what I was referring to.
Also, any controller issues with a swap like this? Would the lower compression of the truck engine play games with the aftermarket controller, say...if I used the 6.4 mopar kit?
I'm so far behind on this gen 3 stuff...still stuck in the LA and RB/B world.
