For Sale - Race Cars - 3rd Quarter #2939350
07/03/21 12:55 PM
07/03/21 12:55 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale - Race Cars - 3rd Quarter [Re: moparts] #2941673
07/09/21 09:38 PM
07/09/21 09:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Duster race car for sale $20k obo, contact me 716-830-125 eight.....
Just sold the engine...
Car has full cage re-certed to 8.50 a couple weeks ago. 4-link rear with anti-roll bar, front has magnumforce coil over conversion. Car is 2750 with the new 440/stroker... Has 16.5x33 D05 Hoosiers and 4.56 gears in a Dana 60.
'70 Cuda,...605 Hemi Street Car (6.20 best pass, 1.33 60ft)
71 Duster Drag Car Roller For Sale
Re: For Sale - Race Cars - 3rd Quarter [Re: moparts] #2941697
07/10/21 12:14 AM
07/10/21 12:14 AM
AndyF Online content
AndyF  Online Content
Car Craft project car "Dustbin Duster", featured in a series of eight articles in Car Craft showing the entire build process. More of a pro street car at the moment but could be converted into a drag car by adding down tubes to the roll bar.
Engine is a 512 inch low deck with Callies crankshaft, Crower rods and ported Mopar 452 aluminum heads. Multiport Holley Dominator fuel injection, intake manifold ported by Wilson Manifolds, Holley coils with 36-1 trigger wheel and CNP ignition. Strange Engineering Ford 9 inch with 35 spline axles, 3.89 gears, S trac differential and Baer 13 inch brakes. Front brakes are 13 inch Baer rotors with Dodge Viper calipers. Transmission is an upgraded 727 with a Turbo Action manual valve body and 10" S-800 converter. Rear suspension is Caltrac mono leafs and bars. Car hooks on the street. Rear tires are 315/50-17 drag radials, tubs will accept a wider tire if wanted.
Interior is set up for drag racing with a race seat and five point Simpson harness. Holley Pro Dash has been programmed to display all EFI information as well as turn indicators and fuel level. The Pro Dash has a GPS speedometer. A Holley handheld is also installed for easy data logging and SD card backup. Four point mild steel roll bar is installed with cross bracing and aluminum paneling. Custom 20 gallon EFI gas tank is bolted to the roll cage above the rear axle.
Holley EFI system has been professionally tuned on the dyno as well as on the street. Engine made 603 hp @ 5900 rpm, idles at 950 rpm with 16 inches of vacuum. EFI system has a built in datalogger with driveshaft rpm, X and Y axis G meter, transmission temp, oil temp, fuel pressure, oil pressure, etc.
Body is straight with most body work complete. Some minor work required on the jambs before it is ready for final paint. Engine compartment has been painted factory white. I have the original driver side bucket seat if a person wants to remove the race seat. I also have a fiberglass hood for the car as well as a complete spare set of window glass, a spare set of bumpers and a pair of doors. All extra parts go with the car. Asking $27,500. CAR IS SOLD
DSC_4642 (Large).JPG (2698 downloads)
DSC_4649 (Large).JPG (2685 downloads)
DSC_4078 (Large).JPG (2684 downloads)
Re: For Sale - Race Cars - 3rd Quarter [Re: moparts] #2941955
07/11/21 02:14 AM
07/11/21 02:14 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
1965 Dodge Dart GT
Very clean southern body , turned into a drag car / street brawler. heater and air box are gone.
Sub frames tied , mini tubbed , springs moved 3" inboard , 10 point cage , cal tracs with mono leafs and Calvert single adjustable shocks on the back , Alterktion with single adjustable QA1's up front.
Wilwood disc brakes on both ends.
Braced 9" with 35 spline Strange center 4.30 spool and spare Strange 3.91 center.
Strange driveshaft , Chuck Lofgren built 904 with low 1st gear and Ultimate converter , 405 inch R-3 tall deck siamese block , BRC 3.79 crankshaft , JE 4.125 pistons , 12.85 : 1 , Bullet solid roller , 626 lift 260 / 268 @ .050 , GS ultra pro lifters , Manton pushrods , ATM innovations 4150 based 1050 , set up for E-85 , Webber Belt cam drive , front mount distributor , MSD 6 AL 2 programmable box , Autometer gauges , Cheetah shifter
W-9 heads done at R&R performance , 349 / 250 @ .600 lift , home made 1 7/8" to 3 1/2 " headers , no step , 32" primaries. 3" exhaust with X pipe exits @ turn downs in front of rear axle.
Maziere remote 55 GPH water pump , 22 gallon fuel tank in trunk , Aeromotive 3000 pump and filter. 3 qt. accu-sump , large aluminum radiator , SSR fan and shroud.
It has three summers of occasional street miles and maybe 10 passes on the track as I tried sorting out traction woes and fuel delivery issues.
Fresh valve springs with less than 100 miles on them.
It is a compromise of sorts , trying to keep street manners and maximize performance.
I can't say that I accomplished either , but will explain to any interested parties.
All good parts throughout.
CAR IS SOLD !!! THANKS MoParts !
Re: For Sale - Race Cars - 3rd Quarter [Re: moparts] #2946782
07/24/21 08:52 PM
07/24/21 08:52 PM
st.louis,mo.
69b1dart Offline
69b1dart  Offline
st.louis,mo.
1969 dodge dart drag car,all fiberglass except roof and quarters,new quarters was used when car was built,which was in late 80s early 90s.alsto sare tubing chassis,a-arm front end,4 link rear,dana 60 456,new strange axles,32x14 hoosiers,weld wheels,500 ci low deck ,230 block,b-1 originals heads,intake holley 1050 on e-85,fender exit headers,727 with brake,8' convertor,set back engine,turbo action air shifter,msd coil,distributor,msd 7al-3.all saftey is expired on everything,which i only ran a outlaw tracks,best et was lsat fall,6.11,normally runs 6.20s,has vin and title,title not in my name,would make a good bracket ,index,no prep car,will trade for a good running gen 2 hemi with aluminum heads,25000.00 pm me here
Re: For Sale - Race Cars - 3rd Quarter [Re: 69b1dart] #2948509
07/29/21 12:48 PM
07/29/21 12:48 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
1966 Plymouth Belvedere I
Street/ Strip
Nostalgia Super Stock Legal
470 Lowdeck
400 block
Eagle Rotating Assembly
Around .500 hydraulic roller
Indy 440-1 Heads
Harland Sharp Rockers
Indy Intake
850 carb redone by Thumper Carbs
Pump Gas motor
Fresh 727
4000 stall converter
reverse manual valve body
1350 Yoke
Cheetah Shifter
8 3/4 rear end
3.91 Gears
Recently rebuilt suregrip
1350 ujoints
3" mild steel driveshaft
Leaf springs
calvert 90/10 shcoks in front
air shocks in rear
20 gallon aluminum cell
Magnafuel 300 pump
weight box
battery in rear
Battery shut off switch
Has run 11.05 at 122mph in 2700ft of air on pro bracket radials.
Car has some scratches and a couple bubbles here and there, but overall it is a very nice consistent car.
Located in Blacklick, OH
Will be running Nostalgia Super Stock at Mopar Nationals in Columbus, OH
$25,000 OBO
Sold with steel rims and new tires on the rear of buyers choice. Slick, drag radials, etc. The race wheels will stay with me or can be purchased for additional $$
Re: For Sale - Race Cars - 3rd Quarter [Re: vttm] #2949937
08/03/21 09:37 AM
08/03/21 09:37 AM
tboomer Offline
tboomer  Offline
Thinking of selling my 64 Dodge. 512 RB with max wedge ported Victors,Indy intake and Holley 1150 Dominator. 4.56 Dana,Ladder bars yadda yadda yadda...I am asking 20 grand and would take a nice B body driver in trade and if it is nice enough I would add some cash. Car will be at Cedar Falls Iowa for the Mopar Max races and show. You cant contact me by pm. Here is a link from last years Mopar Max. The car was driven by Moparts member jericho gtx. (Jeff)
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2813483/1.html
The end is near.....
Re: For Sale - Race Cars - 3rd Quarter [Re: moparts] #2965809
09/20/21 04:44 PM
09/20/21 04:44 PM
OH
junkyardmaxie Offline
OH
1987 dodge dakota truck ROLLER , has new disc brake set up on front, 83/4 rear ,391 gears ,with 11" drum brakes. new coil over ladder bar set up, new rack on front,,new JEGS roll cage kit [NOT INSTALLED] for this truck, has new fiber glass seat and cover and alum seat brackets. has 10 gal alum fuel cell with gage ,also alum battery box,.truck is from NC, cab floor is new condition, body has no rust ever,underneath is great shape also . windshield has a crack in it.needs wiring done has all new wheels ,hoosier good shape as are the front tires. have title would make a great quick street crusier or drag truck ..lots of money spent and time put into truck, health issues force sale. give away price $5250 ohio moparraceman@aol.com or 419 545 0834 text only will get right back to you
20210603_134111 (1).jpg (470 downloads)
20210603_134123 (1).jpg (462 downloads)
20210603_134133 (2).jpg (462 downloads)
20210603_134143 (3).jpg (460 downloads)
