Re: Trans Fluid Leak Down Speedo Cable
[Re: YO7_A66]
#2939419
07/03/21 02:29 PM
07/03/21 02:29 PM
Posts: 19,687 north of coder
moparx
i found the internal o-ring, the one retained by the hair clip snap ring, and also the large o-ring that fits on the outside of the speedometer gear housing. as to the one on the speedometer cable, well, i'm still looking. [for a speedometer cable to see what that o-ring looks like. i know there is one here, just in which "pile-o-stuff" is it in. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) ] if you can't source one locally, i'll get it in an envelope for ya.......... ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#2939450
07/03/21 03:07 PM
07/03/21 03:07 PM
Posts: 26,036 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There is no seal "on the speedometer cable" on the '66 and later. Outer seal on the adapter is an O ring, inner is a molded lip seal.
[Re: John_Kunkel]
#2939586
07/03/21 08:55 PM
07/03/21 08:55 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I will track one down locally, but thank you for looking 👍
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Sniper]
#2939708
07/04/21 09:13 AM
07/04/21 09:13 AM
YO7_A66
Indiana
I just ordered a set of 5 of the "ATP" #SO13 on Amazon for $4.61 and free shipping. My local stores had their own part number with minimal part description. Since some of you already confirmed the brand and part number, I know I have the right part coming. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Thank you again!!
[Re: Montclaire]
#2939710
07/04/21 09:18 AM
07/04/21 09:18 AM
Posts: 1,387 Az
69hemibeep
Az
I had the same problem and fixed it yesterday. I just got my 727 back from being rebuilt and I bought a used housing and gear which came with a new O ring and internal seal which was missing from the transmission. The housing came with a new seal and O-ring and it leaked and ran down the cable. Yesterday I pulled the housing back out and noticed there was no resistance when pushing the gear into the seal so I replaced it with the one the trans shop sent with me out of the rebuild kit. Now I could feel the seal againts the gear and the leak is gone. Some one must be making a seal with the wrong dimensions .
1969 Hemi Roadrunner 2nd owner
[Re: YO7_A66]
#2939907
07/04/21 04:20 PM
07/04/21 04:20 PM
Posts: 15,959 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
And yes lot's of lube is good....where have I heard this before??? Oh that's right...work
Facts are stubborn things.
[Re: YO7_A66]
#2940580
07/06/21 05:33 PM
07/06/21 05:33 PM
YO7_A66
Indiana
Does this look like the right creature? I was expecting one a little larger for some reason. Picture too big but it measures about a half an inch in diameter. Thanks
[Re: YO7_A66]
#2940621
07/06/21 07:37 PM
07/06/21 07:37 PM
YO7_A66
Indiana
Dumb question: the cone shape of the seal goes away or toward the housing? The black one that I pulled had the cone facing outward.
Thanks!
[Re: IMGTX]
#2940639
07/06/21 08:02 PM
07/06/21 08:02 PM
YO7_A66
Indiana
Thanks! The black seal had the cone facing outward! I marked it with a blue paint marker before I removed it from the housing.
[Re: YO7_A66]
#2940658
07/06/21 08:53 PM
07/06/21 08:53 PM
Posts: 15,565 Omaha Ne
TJP
Omaha Ne
The one on the lower right corner (looks dark brown) is how it should be installed into the housing(bottom side first) from the outside in towards the center of the trans. The tan one if installed into the housing (bottom side first)as pictured would be backwards. OR, The recessed side with the lip goes in first towards the center of the transmission Got it ? then install the clip to just touch the seal holding it in place. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
