Re: Stage V Hemi intake w/ spacers
[Re: 4mopower]
#2937620
06/28/21 12:18 PM
06/28/21 12:18 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
I was trying to research this myself but didn't find anything definitive. (whether or not spacers on a carb style efi intake would pick up anything).
[Re: INTMD8]
#2937627
06/28/21 12:28 PM
06/28/21 12:28 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
I've tested them on stock intakes and on Indy 400-3 intake with the tapered reversion Wilson 1.5 inch thick spacers with carbs. , there is power in the spacers on both Your results may vary and may require retuning the motor some
[Re: DoubleD]
#2937671
06/28/21 01:56 PM
06/28/21 01:56 PM
INTMD8
Lake Villa Il
Yes - made a huge difference - almost 2 MPH - evened out the cylinders and cleaned up idle - I used 1" 4 hole super sucker knock-offs made by pro-comp Yes, always seems to help with carbs but would it do anything with EFI is the question.
[Re: sasquatch]
#2937883
06/29/21 06:22 AM
06/29/21 06:22 AM
Posts: 162 Chicago-area Illinois
4mopower
Interesting I haven't heard that before on this Intake. Thanks, John. It also helps to open up the plenum between the front and the back. Todd
