Tunnel ram options above the carbs #2936901
06/26/21 10:37 AM
06/26/21 10:37 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Im not running a hoodscoop. Just air cleaners and carb sticking out the hood. Are velocity stacks (no filter) better than reg chrome air cleaners? I have two 9inch x 2" moroso air cleaners and wondering if they're restrictive. Id think velocity stacks by themselves with no filter would make turbulence at top end. Dont want to mount a hoodscoop on hood.
Re: Tunnel ram options above the carbs [Re: Hot 340] #2936905
06/26/21 10:47 AM
06/26/21 10:47 AM
New York
polyspheric Offline
polyspheric  Offline
New York
A single 2" filter that covers both is better but should be even taller and larger diameter.
Yes, VS have air blown across the entry = bad.
Boffin Emeritus
Re: Tunnel ram options above the carbs [Re: Hot 340] #2936925
06/26/21 11:14 AM
06/26/21 11:14 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Here’s a couple things available. Aeroflow black 9” filters and velocity stacks with screen filter from velocity stacks for hot rods.
A5CC101B-8676-41F6-975C-1809BC958DA7.jpeg25034279-F824-4FDF-BE3E-DBC8C739698C.jpegBB5A3910-BF3A-49EC-B8C5-74EC96171CEB.jpeg
Re: Tunnel ram options above the carbs [Re: mopar dave] #2936928
06/26/21 11:17 AM
06/26/21 11:17 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Pics
4C15A82E-0515-40FE-BCE4-C8844ABF158B.jpegD1804C0B-ECAB-411A-AC70-F72012E01BDF.jpeg5B4FF715-949B-4B87-816D-EF7E653681FF.jpeg
Re: Tunnel ram options above the carbs [Re: mopar dave] #2936937
06/26/21 11:31 AM
06/26/21 11:31 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Pics are all from my phone. Sorry for the sideways pics, but you get the idea. I have not tested these at the track yet, but was suppose to be at the track today testing, rained out again. I understand velocity slacks work better than no velocity stack on a stationary motor like on an engine dyno, but not the best going down track. I see a lot of guys running nothing on top of their t ram carbs at the track. I will be testing this to see for myself sometime this summer maybe fall now. I have also bought a cowl hood scoop to try. Its 4.5" tall and puts the top of the v stacks just poking thru threw top. This i'm told gets it out of the turbulance. The screen tops have options, you can get them with 4,3, 2 or 1 screen for filtering. I opted for the single, because i want it to breath as good as possible. The filters are a goss filter and do produce a bit richer running condition i see on the wideband, but not bad. So, they are a bit more restrictive than the single screen in my opinion. can't wait to test.
Re: Tunnel ram options above the carbs [Re: mopar dave] #2936941
06/26/21 11:40 AM
06/26/21 11:40 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I tried it on my blower motor. No covering on the carbs in an open airstream siphoned fuel out of the bowls. It slowed it down a couple tenths. Believe or not the old triangle Edelbrock air filters were quicker.
Doug
Re: Tunnel ram options above the carbs [Re: dvw] #2936947
06/26/21 11:52 AM
06/26/21 11:52 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Could be, those engineers were sharp. I have been told that can happen with stacks and drilling a small hole at the base of the stack alleviates that. Have not tried that yet. I have been down the freeway at 110+ and never had any fuel on the windshield yet, but i do run short stacks. Tall stacks may be a big issue with that.
Re: Tunnel ram options above the carbs [Re: polyspheric] #2936972
06/26/21 12:46 PM
06/26/21 12:46 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
i could go taller, but not more diameter. Theyll touch. I figured stacks would be no good at speed with nothing to slow the turbulence. 👍
Re: Tunnel ram options above the carbs [Re: mopar dave] #2936973
06/26/21 12:47 PM
06/26/21 12:47 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Wondering if the hilborn style scoops work? Thanks for the pics and info guys..
Re: Tunnel ram options above the carbs [Re: Hot 340] #2936984
06/26/21 01:30 PM
06/26/21 01:30 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I am going to use a sprint car air filter when I get that far. RC2 will supply it with a base for 2x4150 carbs.
Re: Tunnel ram options above the carbs [Re: Jeremiah] #2937014
06/26/21 02:37 PM
06/26/21 02:37 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Do you have a pic?
Re: Tunnel ram options above the carbs [Re: Hot 340] #2937026
06/26/21 03:31 PM
06/26/21 03:31 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The screen stops small birds from entering, but reduces flow by a significant amount.
Boffin Emeritus
Re: Tunnel ram options above the carbs [Re: polyspheric] #2937036
06/26/21 04:19 PM
06/26/21 04:19 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Anything over the top reduces flow, but the screens are the best you can do for filtering and not limiting the least flow impediment. This will all be tested at the track.
Re: Tunnel ram options above the carbs [Re: mopar dave] #2937044
06/26/21 04:44 PM
06/26/21 04:44 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I bet they aren't as good as the filters. If you add up all those wires in the screen it takes up a good majority of the opening.
I am not carbed but I run two throttle bodies on top of a tunnel ram. I usually run it with no filters but running the small K&N filters don't seem to bother it one bit.
68 Barracuda Formula S 340
Re: Tunnel ram options above the carbs [Re: Bad340fish] #2937067
06/26/21 05:49 PM
06/26/21 05:49 PM
Cab_Burge Online work
Cab_Burge  Online Work
Engine dyno testing a 440 stroker bracket motor with a Eddy tunnel ram with two 750 Holey mounted side ways with and with out velocity stacks with 9x3 air cleaner elements on top made more HP and torque than with the stacks and no air cleaners, years ago up
The dyno operator said it would loose power with them before that pull but the owner wanted to run them on the car so he didn't need a hood scoop, it made more horse power and torque and made the AFR slightly better up
Same thing at the 1/4 mile races wit the air cleaners on the velocity stacks versus slower without them work
Re: Tunnel ram options above the carbs [Re: Bad340fish] #2937069
06/26/21 05:53 PM
06/26/21 05:53 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Thats interesting. The filters show richer mixture on the wideband wide open, but no difference idling or cruising than the screened lid. The screened lid show little difference than no lid at all. I really wanted to get to the track today to sort this all out, but its no gonna happen for awhile now.
Re: Tunnel ram options above the carbs [Re: mopar dave] #2937091
06/26/21 07:56 PM
06/26/21 07:56 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Where did you get those screens? I looked at Aeroflows web page, not seeing them there. I'm going to run their TB's but they dont work with the standard air filter & wanted something to keep the rocks out.
Re: Tunnel ram options above the carbs [Re: rebel] #2937093
06/26/21 08:00 PM
06/26/21 08:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I built this from a round K&N. It ran about the same as the triangle Eddy Pro flow. Both better tan open carbs.
Doug
Re: Tunnel ram options above the carbs [Re: rebel] #2937099
06/26/21 08:20 PM
06/26/21 08:20 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
http://www.pjmotorsports.com, velocity stacks for hot rods.
Re: Tunnel ram options above the carbs [Re: dvw] #2937100
06/26/21 08:21 PM
06/26/21 08:21 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I like the looks of that. Both carbs draw from the same large area. I may do something like that in the future. Makes me wonder, think there would be any improvement with putting short velocity stacks between carbs and filter?
