Re: 8 Speed AT in 1970 Charger
[Re: DANA60]
#2937160
06/27/21 01:34 AM
06/27/21 01:34 AM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
[Re: SRT6776]
#2937501
06/27/21 11:02 PM
06/27/21 11:02 PM
Posts: 2,255 IL
furious70
IL
boy that was a lot of work. Holley makes it sound like you just cut out the cross member and use their system, not all that tunnel work.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2937536
06/28/21 04:49 AM
06/28/21 04:49 AM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
boy that was a lot of work. Holley makes it sound like you just cut out the cross member and use their system, not all that tunnel work. True, and I wouldn’t want to cut up a Mopar like that unless it’s a low-dollar car.
China is the enemy.
[Re: A990]
#2938189
06/29/21 09:24 PM
06/29/21 09:24 PM
Posts: 2,255 IL
furious70
IL
that's not what it says.... "1966-72 MOPAR B-BODY GEN III HEMI SWAP COMPONENTS" This particular part says 68-70 b body, not just Charger.
[Re: roadrunninMark]
#2938559
06/30/21 11:02 PM
06/30/21 11:02 PM
Posts: 2,255 IL
furious70
IL
you're using the TF8 with an LA engine?
#2938696
07/01/21 11:57 AM
07/01/21 11:57 AM
Posts: 1,548 Michigan
Kiddart
this is such a really cool idea, i hope this works out for you. What flex plate etc to do the swap are you using
Thank you Kiddart
[Re: Kiddart]
#2938804
07/01/21 04:52 PM
07/01/21 04:52 PM
Posts: 2,937 GA
roadrunninMark
GA
We are using the Quicktime -947 plate, it has to be drilled for the new TQ. We thought about using the stock plate but I talked to Ross at QuickTime and he said it is easier to drill the holes for the converter than it is to drill the holes for the crank. Plus the balance on the plate won't change when drilling the holes for the converter (symmetrical) as it could with the holes for the crank (non symmetrical). The tooth count is 1 less vs. the stock 8hp plate (130 vs. 131) it shouldn't be an issue.
Our next step is to get the spacing off the crank to the plate/converter correct for the input shaft and starter.
Didn't mean to hijack the thread from the original poster.....
[Re: SRT6776]
#2938856
07/01/21 09:12 PM
07/01/21 09:12 PM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
FYI the next generation 8spd has an electric motor in it with something like 235hp and 335lbft Really?....... Any more info?
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2938899
07/02/21 12:46 AM
07/02/21 12:46 AM
Posts: 9,719 Home
SRT6776
Home
"Previously confirmed with electrified assistance by the head of sales operations Matt McAlear, the all-new Charger and Challenger with the fancy 8HP box could arrive in mild-hybrid, hybrid, or plug-in flavors. The most powerful transmission is called 8HP80PH, and in P2 setup for plug-in applications, it cranks out up to 215 horsepower plus 332 pound-feet (450 Nm) of torque.
Combine these figures with the 6.2-liter supercharged V8 of the Super Stock that develops 807 horsepower and 707 pound-feet (959 Nm) on pump gas, and you’ll get 1,022 horsepower and 1,039 pound-feet (1,409 Nm) in total"
Dodge is showing off a new car on July 8th
[Re: DANA60]
#2940997
07/07/21 10:38 PM
07/07/21 10:38 PM
Posts: 2,255 IL
furious70
IL
Holly's cross member will not work with the 90, just the 70. hmmm, I've not seen a difference in the cases documented - do you have any photos?
[Re: furious70]
#2941339
07/08/21 07:50 PM
07/08/21 07:50 PM
Posts: 9,719 Home
SRT6776
Home
Holly's cross member will not work with the 90, just the 70. hmmm, I've not seen a difference in the cases documented - do you have any photos? I have no idea but Ive seen a couple youtubers swap the 70 for a 90 in LX cars and none of them mentioned any difficulty
