Alternators For AR Engineering Motor Plate Kit #2936768
06/25/21 06:40 PM
06/25/21 06:40 PM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
I'm going with the plate and AR-207 kit, but I need more amps to feed my requirements than the Powermaster 8162 or 8172 it was designed for.
Powermaster does make a 75 amp unit in a 93 mm frame, but I'm going to need 100 amp or more.
Anyone find something that would fit with close spacing?
Re: Alternators For AR Engineering Motor Plate Kit [Re: 65Fury440] #2936784
06/25/21 07:23 PM
06/25/21 07:23 PM
AndyF Offline
AndyF  Offline
If you really need more than 100 amps then contact Mechman and see what they can build you. It won't be cheap. https://www.mechman.com/
