dominator question #293655
04/20/09 01:41 AM
04/20/09 01:41 AM
hudson valley n.y.
GEORGE68HEMIRR Offline OP
super street
super street
hudson valley n.y.
did a little welding for my crank evac system on the headers and had a explosion through the headers....so i am pulling off the tunnel ram which i am resealing the valley pan gasket and i am smelling gas from under the car and is dripping out the collectors...after i pulled the tunnelram all the intake valves are wet and the only valve closed was #8 which was full of gas....do you think i blew the power valves in the carbs?...i pulled out the power valves and the rubber looks distorted....what do you think??....would this cause gas to leak out??
Re: dominator question [Re: GEORGE68HEMIRR] #293656
04/20/09 05:29 AM
04/20/09 05:29 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
man that sounds scary....
Mopar Performance
Re: dominator question [Re: moparniac] #293657
04/20/09 10:53 AM
04/20/09 10:53 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
yes i am glad i noticed the gas leaking on the floor before a fire started....does anyone have any advice
Re: dominator question [Re: GEORGE68HEMIRR] #293658
04/20/09 11:28 AM
04/20/09 11:28 AM
Cab_Burge Online work
Cab_Burge  Online Work
replace or plug them and rejet up 6 to 8 sizes if you plug the power valves
Re: dominator question [Re: Cab_Burge] #293659
04/21/09 07:26 AM
04/21/09 07:26 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
ordered new 4.5 pvs and new needle and seats...that should take care of it .....thanks
Re: dominator question [Re: GEORGE68HEMIRR] #293660
04/21/09 07:38 AM
04/21/09 07:38 AM
Q
Quicktree Offline
Quicktree  Offline
Q
how do you know you need 4.5 PV's? whats your vac reading at idle in gear?
Re: dominator question [Re: Quicktree] #293661
04/21/09 07:50 AM
04/21/09 07:50 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
patrick from pro-systems built these 1050s for me and they worked great....patrick is the man and he knows his stuff....when i was building the 572 i gave him all the information about the motor and car
Re: dominator question [Re: GEORGE68HEMIRR] #293662
04/21/09 07:55 AM
04/21/09 07:55 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Patrick knows his stuff but they can't fine tune your car from their shop. you have to do that. thats why you check.
Re: dominator question [Re: Quicktree] #293663
04/21/09 08:11 AM
04/21/09 08:11 AM
Q
Quicktree Offline
Quicktree  Offline
Q
another thing any newer carb has PV protection and wont blow the PV.
Re: dominator question [Re: Quicktree] #293664
04/21/09 09:23 AM
04/21/09 09:23 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Float levels to high,stuck needle valve,loose gasket at PV or PV plug.
Re: dominator question [Re: Quicktree] #293665
04/21/09 09:59 AM
04/21/09 09:59 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
how does that work?.....what is involved in doing that?....yes i may have had a float level problem since gas was sipping out butterfly shaft when i drove it before i blew the pv when it wasnt running while welding evac tube in headers
Re: dominator question [Re: Quicktree] #293666
04/21/09 10:01 AM
04/21/09 10:01 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
just called jegs and that protection is for the 4150/4160 carbs.....not the dominator
Re: dominator question [Re: GEORGE68HEMIRR] #293667
04/21/09 02:24 PM
04/21/09 02:24 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
when you take off the metering block, if there is gas behind it, the PV is a blown. sounds like the needle and seat was stuck open though
Re: dominator question [Re: sixpackgut] #293668
04/21/09 03:29 PM
04/21/09 03:29 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
well i ordered new 120 needle and seats and new pvs....so hopefully this does it and i will set float levels
