Page 2 of 3 1 2 3
Re: 906 heads, home port vs. "Pro" job [Re: fast68plymouth] #29380
08/30/06 11:32 PM
08/30/06 11:32 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Great low lift #'s. Did you do much with the push rod pinch?
Re: 906 heads, home port vs. "Pro" job [Re: MR_P_BODY] #29381
08/30/06 11:38 PM
08/30/06 11:38 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Very informative. Nice work on the ports.
So Dwayne, what would the stock head flow before
cutting the tree limbs out of the way(nothing done)
just a average number intake and exhaust?
I would also like an answer to this please
Re: 906 heads, home port vs. "Pro" job [Re: ccdave] #29382
08/30/06 11:54 PM
08/30/06 11:54 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Mr. P body, the stock 906's ive tested have flowed from the mid-220's to as well as the high 230's with no porting.
just depends on the head.
most std exhaust ports are in the low-mid-150's.
CCDave, it basically took me 2hrs per head to update the porting. its about 30mins per cylinder, and thats broken down to about 22mins per intake port, 8mins per exhaust(in this instance), and about 15-17mins of what was done to the intake port was spent reshaping the short turn.
on a 346/902/452 head.....it would have been about 60-70% of that amount of time(less than 1.5hrs per head).
nonetheless, a nearly 30cfm gain on both sides of the head, well within a usable lift range, for 4hrs labor....is well worth the time and effort IMO.
the pushrod pinch area has been smoothed and blended some by whoever did the original porting.
i didnt even measure the width at the pinch.....but i'll check a few of them tomorrow and see about where they are.
i didnt do any additional work in that area of the head.
Re: 906 heads, home port vs. "Pro" job [Re: fast68plymouth] #29383
08/31/06 12:07 AM
08/31/06 12:07 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Great info Dwayne
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: 906 heads, home port vs. "Pro" job [Re: fast68plymouth] #29384
08/31/06 12:08 AM
08/31/06 12:08 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Very good info.Thanks for taking the time to post and the pictures too!!
Nautilus Racing-
Re: 906 heads, home port vs. "Pro" job [Re: fast68plymouth] #29385
08/31/06 12:08 AM
08/31/06 12:08 AM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
Dwayne - for the seats, VJ, and porting, safe to assume around $500 - $600 into the set of heads? Just asking to point out cost comparisions to Eddy heads. I'm still a firm believer that OEM heads still have their place today.
You can sure tell the difference between the 2 VJ's. Whoever did them, they had a pretty wide seat from the looks of the pic.
Great post as usual
1967 Satellite, CNC Eddy Headed 500ci Street Mauler
(Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell
2012 Hemi Ram Sport Crew Cab
2011 Avenger, Pentastar V-6
2007 SRT-8 Charger (Dyno'ed @ 470 RWHP)
1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
Re: 906 heads, home port vs. "Pro" job [Re: fast68plymouth] #29386
08/31/06 12:16 AM
08/31/06 12:16 AM
So. Burlington, Vt.
So. Burlington, Vt.
the numbers....side by side
intake port:
lift----B/A---gain
.100--73.1/69.5-- -3.6
.200-133.7/145.5- +11.8
.300-196.4/208.5- +12.1
.400-237.1/257.9- +20.8
.450-241.9/270.7- +28.8
.500-240.3/265.9- +25.6
.550-243.5/269.1- +25.6
.600-241.9/270.7- +28.8
.650-233.9/267.5- +33.6
.700-230.7/261.5- +30.8
exhaust port:
lift----B/A---gain
.100--55.9/56.3-- +0.4
.200-112.3/112.3- +0.0
.300-151.5/158.4- +6.9
.400-163.5/179.2- +15.7
.450-167.4/187.1- +19.7
.500-168.7/189.7- +21.0
.550-168.7/194.9- +26.2
.600-167.4/197.5- +30.1
.650-167.4/201.4- +34.0
.700-166.1/204.1- +38.0
Re: 906 heads, home port vs. "Pro" job [Re: Mills] #29387
08/31/06 12:24 AM
08/31/06 12:24 AM
So. Burlington, Vt.
So. Burlington, Vt.
Mills.....the price to update these heads is going to be about $580-$600.
-disassemble heads, flow test
-install hardened exhaust seats
-machine seats and bowls
-back cut intake valves
-4hrs porting + additional flow testing
-wash heads & parts, assemble, set spring pressures
if they were being done from scratch, to this same level of modification(parts and labor), they would easily cost a few hundred more than a new set of E heads.
Re: 906 heads, home port vs. "Pro" job [Re: fast68plymouth] #29388
08/31/06 12:50 AM
08/31/06 12:50 AM
FastOne Offline
FastOne  Offline
Iron heads shall rise again...LOL!
This topic proves it's worthwhile sending your heads to someone that does porting all the time & uses a flow bench
Re: 906 heads, home port vs. "Pro" job [Re: fast68plymouth] #29389
08/31/06 12:51 AM
08/31/06 12:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Great info Dwayne. These are my 906 heads on my 63 that I did and installed the 2.14 and 1.81 valves. Hope they work good enough to beat my boys Dart. Ron
Re: 906 heads, home port vs. "Pro" job [Re: fast68plymouth] #29390
08/31/06 01:47 AM
08/31/06 01:47 AM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
I figured it would be in that range. I re-read my other post - I meant the BEFORE seat width looked wide when compared to yours. Sorry
Re: 906 heads, home port vs. "Pro" job [Re: fast68plymouth] #29391
08/31/06 02:37 AM
08/31/06 02:37 AM
this is what the finished job looks like.
i didnt do anything to the port openings because at this stage of the game, thats purely eye candy.
What have you found as far as "results" on a high-polish in the combustion chambers ?
Or is that just eye-candy ?
And on a typical 906 or 452 ....what is the diff in CC's in that chamber ....dead-stock vs highly polished ?
Re: 906 heads, home port vs. "Pro" job #29392
08/31/06 03:08 AM
08/31/06 03:08 AM
no big deal but would be nice if the poster/teacher could make ALL his posts/points one right after the other BEFORE any other comments are posted.
sort of like a professor gives his lesson and then opens it up for debate.
no big deal though - good info.
Re: 906 heads, home port vs. "Pro" job #29393
08/31/06 05:08 AM
08/31/06 05:08 AM
Cambridge Vt.
mark_gates Offline
mark_gates  Offline
Cambridge Vt.
How many other head porters would take you step-by-step thru his process, explaining with pics what, how and why he does what he does? That's intellectual property ! Thanks Dwayne, for your unselfish contributions. As always, you da man!
Re: 906 heads, home port vs. "Pro" job [Re: mark_gates] #29394
08/31/06 07:08 AM
08/31/06 07:08 AM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Great info here Dwayne.... I have done a set of 452's at home and I just tried to copy what I saw him do and follow his lead. I have no practical knowledge of reshaping the short turn on the intake side so all I did was give it a gentle radius. This is archive material for sure... TBF
Re: 906 heads, home port vs. "Pro" job [Re: tpabayflyer] #29395
08/31/06 07:15 AM
08/31/06 07:15 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Yepper.
Soon as the chatter dies down it's going to get moved!
Re: 906 heads, home port vs. "Pro" job [Re: fast68plymouth] #29396
08/31/06 10:34 AM
08/31/06 10:34 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Hey
Did you happen to get a good shot of the before and after of the short tun rework???
Re: 906 heads, home port vs. "Pro" job [Re: ZIPPY] #29397
08/31/06 11:03 AM
08/31/06 11:03 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Yepper.
And for those who aren't aware, there are already a couple of Dwayne's old threads on OEM heads (prep work & porting results) in the Tech Archive section that are well worth looking over if this thread captures your interest.
In no particular order:
http://www.moparts.com/Tech/Archive/bb/62.html
http://www.moparts.com/Tech/Archive/bb/40.html
http://www.moparts.com/Tech/Archive/bb/42.html
Re: 906 heads, home port vs. "Pro" job [Re: ccdave] #29398
08/31/06 11:16 AM
08/31/06 11:16 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Dwayne,
What happened on the Intake side at .450? Flow went from 257.9 at .400 to 270 at .450, then back down to 265.9 at .500. Looks like turbulance starts at the .650 range so the rise in flow, than the dip between .400 and .500 seems odd.
lift----I/E
.100--69.5/56.3
.200-145.5/112.3
.300-208.5/158.4
.400-257.9/179.2
.450-270.7/187.1
.500-265.9/189.7
.550-269.1/194.9
.600-270.7/197.5
.650-267.5/201.4
.700-261.1/204.1
Re: 906 heads, home port vs. "Pro" job [Re: mark_gates] #29399
08/31/06 01:16 PM
08/31/06 01:16 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I agree""
I myself made the classic mistake of not touching the short turn. Dwayne unselfishly showed me what I did wrong and even fixed a port for so I could use it as a example to fix the rest. Great guy my hats off to him. mike
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
Page 2 of 3 1 2 3
