Re: Big Hemi breaks up over 6000. Valve springs?? [Re: dthemi] #2936449
06/24/21 03:23 PM
06/24/21 03:23 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
Thanks for all of the good input guys.
I'll do some testing to rule out fuel and ignition. Don't have any way to log data.
I was hoping someone had success with adding 20# with some shims and calling it a day. grin I guess nothing's that easy (although I did cure a similar issue that way with a W-2 stroker motor, but it had TONS of installed height to work with).
If I had to build this one again, I'd probably skip the roller set-up and just go with a flat tappet... more cam choices (street) and would save a LOT of $ and a lot of pushrod clearancing work, etc.
Re: Big Hemi breaks up over 6000. Valve springs?? [Re: WarEagle1] #2936583
06/25/21 12:01 AM
06/25/21 12:01 AM
I would look at installing a .060 shim in one cylinder and then check for coil bind at your current lift, if it has .100 + to coil bind run it. scope up
If it has less than .050 don't down
