Gas tank float #29357
08/27/06 02:36 AM
08/27/06 02:36 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I remeber someone mentioning that there is a Ford part number for a replacment plastic float for the sending unit that would pop into place of a damaged unit in a Mopar gas tank.
Does anyone know what I am talking about or recall the post in question ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Gas tank float [Re: AlexP] #29358
08/27/06 03:17 AM
08/27/06 03:17 AM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
I'm sure if you go into a (gasp!) Ford dealership and tell them what you need they will get you one. I know they where used at least through the mid '90's.
Eric
Re: Gas tank float [Re: Erics5th] #29359
08/27/06 03:21 AM
08/27/06 03:21 AM
COAZ-9202-B, but it's brass not plastic.
