Oil pick up tube to rod clearest
#2934919
06/19/21 08:05 PM
06/19/21 08:05 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Do you think .010 is ok ? or need more . only way I can get more is to grind on the rod a little ( My bad .010 )
Re: Oil pick up tube to rod clearest
[Re: B1MAXX]
#2934936
06/19/21 09:24 PM
06/19/21 09:24 PM
Posts: 3,106 Michigan
A727Tflite
i would say .050 min. Can you bend the tube over slightly? Ding the tube? If its a Moroso with the sleeve can you grind it? He has .10” now.
[Re: VernMotor]
#2934940
06/19/21 10:05 PM
06/19/21 10:05 PM
Posts: 43,332 Bend,OR USA
Cab_Burge
I've use .030 rod to tube at room temps. without any issues later on stock rod bolts and nuts, same on after market I beam and H beam bolts
[Re: mshred]
#2935702
06/22/21 04:21 PM
06/22/21 04:21 PM
VernMotor
Mt.Vernon ,Ohio
What stroke is this for? Pickup tube diameter? 3/8 pick up and 4.15 stroke
