Re: Thought I share this Carb adapter [Re: VernMotor] #2934089
06/16/21 10:17 PM
06/16/21 10:17 PM
TN Hoosier
jb500 Online content
jb500  Online Content
TN Hoosier
Nice piece, i should have filed a patent 6 years ago when I came up with the same idea and made my own to fit a 4150 on my M1 4500 intake. The pic shows the combo plate and a 4 hole spacer.
Made mine for the price of scrap aluminum 1/2" plate and my Dad's time on the mill. He has since retired and so did my freebies with the mill until I get my own unit.
Re: Thought I share this Carb adapter [Re: jb500] #2934091
06/16/21 10:32 PM
06/16/21 10:32 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
You would have probably spent more getting the patent than it would have made for you, it's not a spacer design that is overly prevelant.
Regardless, a clever solution to a problem. Although changing over to a dual pattern base plate is another way of getting the same result. The 4150-4500 spacers I've made took advantage of that.
Alan Jones
Re: Thought I share this Carb adapter [Re: LA360] #2934098
06/16/21 10:41 PM
06/16/21 10:41 PM
TN Hoosier
TN Hoosier
True on the ROI. It was more in jest than an actual hand to forehead moment.
I saw a problem and was determined to make it work without spending more coin on a newer carb base.
Real simple solution would be to run a Dommy and be done with it all together. 😀
Re: Thought I share this Carb adapter [Re: jb500] #2934507
06/18/21 11:39 AM
06/18/21 11:39 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The 540" B1 in my Savoy has an adapter to a 4150 for NSS type stuff. Runs 8.90/5.70 at 3450 that way.
