Thought I share this Carb adapter #2933666
06/15/21 06:28 PM
06/15/21 06:28 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Don't think you can buy a max wedge intake with a 4150 flange . at lease I could not find one . nothing available. and I run NSS so I can only run a 4150 carb. I bought T/F 270 heads and a Indy intake . It has a 4500 flange . I have hood clearest problems So most of the adapter are 2" tall would not work for me..so I bought this adapter. Very nice part .
Re: Thought I share this Carb adapter [Re: VernMotor] #2933667
06/15/21 06:29 PM
06/15/21 06:29 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
2 more pictures
Re: Thought I share this Carb adapter [Re: VernMotor] #2933671
06/15/21 06:35 PM
06/15/21 06:35 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I have an Indy intake for a RB with max wedge ports, it has a 4150 flange.
Re: Thought I share this Carb adapter [Re: Dodgeguy101] #2933676
06/15/21 06:49 PM
06/15/21 06:49 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I know they made them. I just could not find one. And if I decide to bracket race. I can take the adapter off and put my dominator on and I think it will be faster ? maybe LOL
Re: Thought I share this Carb adapter [Re: VernMotor] #2933680
06/15/21 07:14 PM
06/15/21 07:14 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
How did you find this spacer? Was it recommended by someone or you found it on eBay? Just curious as you're in Ohio and this was made in country Victoria, Australia.
Alan Jones
Re: Thought I share this Carb adapter [Re: LA360] #2933683
06/15/21 07:23 PM
06/15/21 07:23 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Nice! How tall is it? Wilson makes a 1.5in adapter.
Re: Thought I share this Carb adapter [Re: VernMotor] #2933684
06/15/21 07:24 PM
06/15/21 07:24 PM
tboomer Online work
tboomer  Online Work
That's pretty interesting. Expensive? wave
Re: Thought I share this Carb adapter [Re: LA360] #2933690
06/15/21 07:47 PM
06/15/21 07:47 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Just did a search...
Re: Thought I share this Carb adapter [Re: gsmopar] #2933692
06/15/21 07:49 PM
06/15/21 07:49 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
( 1" )
Re: Thought I share this Carb adapter [Re: tboomer] #2933694
06/15/21 07:50 PM
06/15/21 07:50 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Not cheap less than 200
Re: Thought I share this Carb adapter [Re: VernMotor] #2933698
06/15/21 08:03 PM
06/15/21 08:03 PM
LA360 Offline
LA360  Offline
Alan Jones
Re: Thought I share this Carb adapter [Re: LA360] #2933713
06/15/21 08:23 PM
06/15/21 08:23 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Glad mine was not that much .
Re: Thought I share this Carb adapter [Re: VernMotor] #2933721
06/15/21 08:41 PM
06/15/21 08:41 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
So you can run “any” 4150” carb? ....or something period correct?
Re: Thought I share this Carb adapter [Re: J_BODY] #2933739
06/15/21 09:33 PM
06/15/21 09:33 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Yea they change the rules last year. you can run a 4150 carb but no billet center
Re: Thought I share this Carb adapter [Re: VernMotor] #2933784
06/16/21 12:14 AM
06/16/21 12:14 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Here's a dual plane Indy Max Wedge 4150
Re: Thought I share this Carb adapter [Re: VernMotor] #2933825
06/16/21 07:08 AM
06/16/21 07:08 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
That is pretty sweet.
Re: Thought I share this Carb adapter [Re: 80fbody] #2933836
06/16/21 08:07 AM
06/16/21 08:07 AM
an8sec70cuda Offline
iagree Looks nice!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Thought I share this Carb adapter [Re: an8sec70cuda] #2933929
06/16/21 01:12 PM
06/16/21 01:12 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
A lot of the newer 4150 carbs will bolt to a 4500 as they have elongated holes.
That is a cool adapter though!
Casey FJ
Re: Thought I share this Carb adapter [Re: VernMotor] #2933944
06/16/21 01:58 PM
06/16/21 01:58 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Must be nice to be rich and be able to afford all the trick stuff…..😁👍😎
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Thought I share this Carb adapter [Re: VernMotor] #2933962
06/16/21 02:57 PM
06/16/21 02:57 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Nice piece! ... Mr Gasket made an adapter plate using cheezy bent studs. It was only .500" thick. Part number 1930 but, is no longer made...
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
