1946 Dodge pickup , big block and wide fenders #2932830
06/13/21 03:05 PM
06/13/21 03:05 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Made it fit with a wide body kit
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1946 Dodge pickup , big block and wide fenders [Re: bigdad] #2932831
06/13/21 03:06 PM
06/13/21 03:06 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
More pics
Re: 1946 Dodge pickup , big block and wide fenders [Re: bigdad] #2932833
06/13/21 03:07 PM
06/13/21 03:07 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
last one
Re: 1946 Dodge pickup , big block and wide fenders [Re: bigdad] #2932838
06/13/21 03:16 PM
06/13/21 03:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Craptastic sums it up.
Re: 1946 Dodge pickup , big block and wide fenders [Re: bigdad] #2933487
06/15/21 10:01 AM
06/15/21 10:01 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I’d like to know what chassis it sets on. I like it. up
Re: 1946 Dodge pickup , big block and wide fenders [Re: Dabee] #2933562
06/15/21 01:41 PM
06/15/21 01:41 PM
moparx Online content
moparx  Online Content
parts of that i like, some i'm not sure of.
chassis details would be interesting to find out.
beer
Re: 1946 Dodge pickup , big block and wide fenders [Re: moparx] #2933733
06/15/21 09:15 PM
06/15/21 09:15 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Based on the position of the outside edge of the front tires with the 3" fender extensions, I'd say its an early (88-96) Dakota chassis (looks to have 5 bolt wheels, without the fender extensions, the Dakota chassis puts the outside edge of the tires about even with the fender lip) . An S10 chassis would have the front tires nearly out of site with the fender extensions (the tires usually sit inside the fenders a good 4" without the fender extensions). The truck sits pretty low to have the original beam front axle with the big block sitting where it is (the oil pan sump would be in about the same position as the axle.
At least that's my guess based on having built a couple of this era Dodge trucks. Gene
Re: 1946 Dodge pickup , big block and wide fenders [Re: poorboy] #2933740
06/15/21 09:36 PM
06/15/21 09:36 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
That’s what I was thinking based on how he has the bed floor raised up.
Re: 1946 Dodge pickup , big block and wide fenders [Re: Dabee] #2933745
06/15/21 09:50 PM
06/15/21 09:50 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yea, that too! LOL Gene
Re: 1946 Dodge pickup , big block and wide fenders [Re: poorboy] #2934540
06/18/21 12:34 PM
06/18/21 12:34 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Well, it is called expanded metal.
I guess he took it literally.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 1946 Dodge pickup , big block and wide fenders [Re: wingman] #2934670
06/18/21 07:53 PM
06/18/21 07:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Those fenders are probably slightly better then having no fenders, if a guy got caught in a rain storm.
Re: 1946 Dodge pickup , big block and wide fenders [Re: poorboy] #2934797
06/19/21 10:35 AM
06/19/21 10:35 AM
South-east Mn
blaze Offline
blaze  Offline
South-east Mn
Did it start out as a 3/4 ton or a 1 ton. Just curious judging by the looong box. Or did it get extended also?
Re: 1946 Dodge pickup , big block and wide fenders [Re: blaze] #2935117
06/20/21 07:55 PM
06/20/21 07:55 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
It looks like he added a piece in the bed side above the rear fenders. Probably because it was a long wheel base Dakota chassis, and he wanted the extra space for the radiator to fit into the box behind the cab. I've built those box sides from sheet steel, the section above the fenders doesn't have any body lines visible with the fenders bolted on.
