Re: no oil pressure on start up
[Re: lancer493]
#2929119
06/01/21 10:25 AM
06/01/21 10:25 AM
Posts: 1,229 In The Hills
jughed
In The Hills
.... One thing that was mentioned here was how many people were using only a single line external pick up capping off a second line ,and maintaining good lubrication performance even at upper rpm levels. What hadn't occurred to me til now is the possibility of ,after being shut down for an extended period of time, the same oil pump may have to refill two empty pick up lines (twice the volume) theoretically taking twice the time. No matter if using single or double line, the pump will remain primed if the single or 2 lines are placed anywhere above the pump. The oil level in the lines will not be below the oil level in the pan. They will not empty if there is oil in the pan. Some will claim that their car can defy the laws of physics.
[Re: jughed]
#2929181
06/01/21 02:26 PM
06/01/21 02:26 PM
Posts: 781 wine country
8urvette
wine country
.... One thing that was mentioned here was how many people were using only a single line external pick up capping off a second line ,and maintaining good lubrication performance even at upper rpm levels. What hadn't occurred to me til now is the possibility of ,after being shut down for an extended period of time, the same oil pump may have to refill two empty pick up lines (twice the volume) theoretically taking twice the time. No matter if using single or double line, the pump will remain primed if the single or 2 lines are placed anywhere above the pump. The oil level in the lines will not be below the oil level in the pan. They will not empty if there is oil in the pan. Some will claim that their car can defy the laws of physics. Then maybe I have no problem, I do appreciate you clearing this up.
[Re: Uberpube]
#2929354
06/01/21 11:28 PM
06/01/21 11:28 PM
8urvette
wine country
I work on a lot of large reciprocating compressors that are built just like engines on the bottom end with shell bearings and gear pumps. Those compressors have oil failure controls that have a thermal timer to allow for oil pressure delay on startup. If it makes you feel any better, those time delays are from 45-120 seconds to avoid nuisance trips of the control and the go 0 to 1750 rpm in a split second, to full load. Are you using through the pushrod oiling and what rockers? What's the lash set to? I'm just thinking of how much volume there is to refill in your motor when it's been sitting for a while. T&D rockers, through pushrod oiling last is set to crane spec of .28!!!!! im looking at what accumulator system to go with... UGH!!!! I plan on pulling the motor next weekend, redoing a few leaky gaskets and fix the leaky trans seal while i am at it.
[Re: 8urvette]
#2929356
06/01/21 11:36 PM
06/01/21 11:36 PM
Posts: 3,089 Michigan
A727Tflite
I work on a lot of large reciprocating compressors that are built just like engines on the bottom end with shell bearings and gear pumps. Those compressors have oil failure controls that have a thermal timer to allow for oil pressure delay on startup. If it makes you feel any better, those time delays are from 45-120 seconds to avoid nuisance trips of the control and the go 0 to 1750 rpm in a split second, to full load. Are you using through the pushrod oiling and what rockers? What's the lash set to? I'm just thinking of how much volume there is to refill in your motor when it's been sitting for a while. T&D rockers, through pushrod oiling last is set to crane spec of .28!!!!! im looking at what accumulator system to go with... UGH!!!! I plan on pulling the motor next weekend, redoing a few leaky gaskets and fix the leaky trans seal while i am at it. X
[Re: jughed]
#2929465
06/02/21 12:37 PM
06/02/21 12:37 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
I've noticed a huge difference on how quickly a mechanical pressure gauge reacts, based only on the type of line feeding it.
I've not used bigger ID AN line, but eventually I will try.
But on the two others I have tried, the usual crappy white nylon and copper/off the shelf autometer kits......there is a huge difference in gauge reaction time. The nylon reacts much faster... and the copper is very slow and almost gives the appearance there is a problem.
Rich H.
Esse Quam Videri
[Re: 8urvette]
#2933082
06/14/21 09:03 AM
06/14/21 09:03 AM
ZIPPY
S.E. Michigan
No, full groove mains don't really affect pump prime.
Rich H.
Esse Quam Videri
[Re: dthemi]
#2933478
06/15/21 09:26 AM
06/15/21 09:26 AM
8urvette
wine country
Accusump is a bandaid for an oil system problem. Fix the problem, and you won't have to lug all that stuff down the track. Easy to say... hard to find.
