magnum force double adjustable control arms #2933335
06/14/21 08:55 PM
06/14/21 08:55 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
anyone run these on the street. any problems thks Danny
Re: magnum force double adjustable control arms [Re: plycuda] #2933384
06/14/21 10:23 PM
06/14/21 10:23 PM
California
BloFish Offline
BloFish  Offline
California
I have heard nothing good regarding that company. I would steer clear, just my .02
It really doesn't matter whether you win or loose...
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab 2500
‘14 Mercedes-Benz SLK
Re: magnum force double adjustable control arms [Re: BloFish] #2933391
06/14/21 10:37 PM
06/14/21 10:37 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I would like to hear the good / bad as well, I have their drop spindles and had no problems, was thinking of buying their transformer front suspension
Re: magnum force double adjustable control arms [Re: dangina] #2933395
06/14/21 10:55 PM
06/14/21 10:55 PM
California
BloFish Offline
BloFish  Offline
California
Do a search on this site, los of threads about them.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab 2500
Re: magnum force double adjustable control arms [Re: BloFish] #2933450
06/15/21 08:25 AM
06/15/21 08:25 AM
Trumussia
jcc Offline
jcc  Offline
Trumussia
I have nothing to share to dispute the above.
However, I will consider anything individually to decide its useful merit for my application, and assume any risk therein.
That said, I know nothing of which the OP speaks, what are they, is this something new?
If you can't dazzle them with diamonds, don't waste your time, because nothing will
Re: magnum force double adjustable control arms [Re: plycuda] #2933615
06/15/21 04:16 PM
06/15/21 04:16 PM
Santa Rosa, Calif
angleiron2 Offline
angleiron2  Offline
Santa Rosa, Calif
I have had them on my 69 Dart for a few years and they work fine. I had no problems when with the order or delivery. Recently I ordered a set of tubular a arms for our 66 Coronet and this time I chose SPC to get away from the Hemi joints. They both make alignment easy.
