How many passes have you made on a race weekend? #2931925
06/10/21 11:17 AM
06/10/21 11:17 AM
MN
JERICOGTX Offline OP
MN
My buddy, and his daughter, run their car in two classes when they go racing. He runs Pro, and she runs Super Pro. The car is setup simple for seat adjustment, and removal of the delay box for driver swaps. Over Memorial Day Weekend, they put a total of 51 passes on the car. She won Super Pro on Saturday, and he made it to the Semi Finals on Sunday.
69 GTX 68 Road Runner
Re: How many passes have you made on a race weekend? [Re: JERICOGTX] #2931933
06/10/21 11:38 AM
06/10/21 11:38 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
eek
Not that many!!
Love that first pic up
Re: How many passes have you made on a race weekend? [Re: fast68plymouth] #2931950
06/10/21 12:01 PM
06/10/21 12:01 PM
MN
MN
I have to give a big shout out to Dwayne Porter, as this combo went from a set of cracked/ leaking set of INDY EZ heads, to a Porter Racing Heads prepped set of INDY SR 295CNC heads. The car picked up 2/10's, and a couple MPH, with nothing else changed.
Re: How many passes have you made on a race weekend? [Re: JERICOGTX] #2931953
06/10/21 12:19 PM
06/10/21 12:19 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
On a good 3 day weekend been 17-18 passes in one class.
Doug
Re: How many passes have you made on a race weekend? [Re: dvw] #2931959
06/10/21 12:35 PM
06/10/21 12:35 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I won’t mention any names but one of our members runs three classes at the Mopar races and he always goes rounds.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: How many passes have you made on a race weekend? [Re: JERICOGTX] #2931963
06/10/21 12:44 PM
06/10/21 12:44 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
That's making a ton of laps in a weekend. Most keyboard racers probably don't make that many passes a year. A Decent 3 day weekend running 1 class I'll make 12-14 (We only get 1 time run per day). Most I've made in 1 day has been 14 passes running 2 classes.
Re: How many passes have you made on a race weekend? [Re: DusterKid] #2931970
06/10/21 01:10 PM
06/10/21 01:10 PM
Locomotion Offline
Locomotion  Offline
IHRA had a triple-header divisional race in Jackson, SC because of a rain-out several years ago. I must have made 20+ passes in my Dart Sport, Stock class each day. Won Fri. & Sat. and got runner-up on Sunday.
Re: How many passes have you made on a race weekend? [Re: Locomotion] #2931972
06/10/21 01:14 PM
06/10/21 01:14 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Made 24 at Holley Moparty last Sept at Bowling Green
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: How many passes have you made on a race weekend? [Re: B3422W5] #2931976
06/10/21 01:24 PM
06/10/21 01:24 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
51 that is impressive!
I would like to try the multiple class thing at the right event. My car is ready for another pass quickly, even faster if I leave the hood off. I suppose trans temp would be my enemy in a hot lap situation, but no gauge no problem right? lol
68 Barracuda Formula S 340
Re: How many passes have you made on a race weekend? [Re: Bad340fish] #2931985
06/10/21 01:38 PM
06/10/21 01:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I made 11 this past sat running two classes....Would have been 13 had the car not broke...finished in the semis in both classes....In a 3-day weekend, I would be out of parts and money....
Re: How many passes have you made on a race weekend? [Re: JERICOGTX] #2931998
06/10/21 02:19 PM
06/10/21 02:19 PM
AndyF Offline
AndyF  Offline
51 passes is a lot. Almost have to do maintenance during the weekend with that many passes. Some transmission vendors want a band adjustment every dozen passes so you would be sliding under the car a few times on a weekend like that.
Re: How many passes have you made on a race weekend? [Re: AndyF] #2932004
06/10/21 02:47 PM
06/10/21 02:47 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Were they both double-entered, we are starting to see a lot of cars doing that at our local track.
My other thought is that one small failure like a rocker adjuster could knock both drivers out, better to have two cars.
Re: How many passes have you made on a race weekend? [Re: cgall] #2932012
06/10/21 03:00 PM
06/10/21 03:00 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I have a customer who double enters both classes and runs some gamblers and such that can (he has several times) crack 50 a weekend at a Norwalk Mopar type event. Todd
Re: How many passes have you made on a race weekend? [Re: JERICOGTX] #2932017
06/10/21 03:06 PM
06/10/21 03:06 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I'm confused about the logistics of this....doesn't add up in my head. 2 time runs apiece for 3 days is 12 runs (I'm assuming 3 day race, since it was not specified), then they would have to go more than 6 rounds EACH every day....how many folks are that good/lucky? work work
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: How many passes have you made on a race weekend? [Re: JERICOGTX] #2932029
06/10/21 03:55 PM
06/10/21 03:55 PM
an8sec70cuda Offline
Wow, that's a bunch of runs and they're clearly very good at what they do!
I think I've made 9 or 10 passes in one night.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How many passes have you made on a race weekend? [Re: JERICOGTX] #2932036
06/10/21 04:19 PM
06/10/21 04:19 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
As much as these cars cost to build and maintain they should all be driven that hard and asking for more. I always tried to enter every class I could get in, as long as the run order wasn't rediculous. Probably 25ish in a weekend for me if I recall. 51 is rediculous, got their entry fees worth!
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: How many passes have you made on a race weekend? [Re: FlyFish] #2932049
06/10/21 04:55 PM
06/10/21 04:55 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Yep, I'm with you. I usually get in one class. So, on a good day, with two time trials, I may get in 3 runs. LOL! You guys that are getting double digit runs are way too professional. (not to mention the entry fees involved?) Again, LOL !!!!!!
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: How many passes have you made on a race weekend? [Re: A39Coronet] #2932050
06/10/21 04:56 PM
06/10/21 04:56 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
My son made 31 passes at Cecil one weekend. Running two classes and went to semis in both.
Most i made was at the last Monster Mopar i made 15 passes
....BAD A$$ STREET CAR.....
Re: How many passes have you made on a race weekend? [Re: n20mstr] #2932058
06/10/21 05:32 PM
06/10/21 05:32 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
we dont get multi event weekends here . 1 race in 1 , 2 or 3 days .
If i go to finals its normally 8 passes , 3 qual and 5 rounds occasionaly 6 .
On sunday @ T&T i went 7 passes in about 3 hours . I think i did 12 once .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: How many passes have you made on a race weekend? [Re: tex013] #2932166
06/11/21 12:24 AM
06/11/21 12:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Most I’ve done in awhile was 10.... 3 test hits, 1st and 2nd round Saturday. 5 rounds to the finals on Sunday where I threw it all in the trash.
