Intermittent alternator operation
#2931921
06/10/21 11:10 AM
06/10/21 11:10 AM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
Hi, on my '67 GTX the alternator operates intermittently. Sometimes it will work for 5 or 10 minutes then be off for 20 minutes or more. I replaced the regulator, that didn't do anything, I checked all the wiring and the grounds and that was okay. I brought the alternator in to a professional rebuilding shop and had it rebuilt. When it decides that it is not going to work, I can apply 12 volts to the field terminal and it does not operate. What could it be inside this alternator that could be causing this? I want to have an idea before I bring it back to the rebuild shop, because most likely they will tell me it's not the alternator it's the car.
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Intermittent alternator operation
[Re: Hemi_Joel]
#2931932
06/10/21 11:36 AM
06/10/21 11:36 AM
Posts: 10,666 North Dakota
6PakBee
North Dakota
Replace the bushes.
Missed the fact that it was rebuilt. The brushes would have been replaced as standard operating procedure by any competent shop. Ignore my comment.
[Re: Hemi_Joel]
#2931997
06/10/21 02:18 PM
06/10/21 02:18 PM
Posts: 18,389 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Thanks, Joel When you field the alternator make sure there is voltage on the alternator stud. If you are losing the battery feed at the time you are fielding it the alternator will not put out.
[Re: ph23vo]
#2932001
06/10/21 02:41 PM
06/10/21 02:41 PM
Posts: 86 Alabama
WarEagle1
Alabama
sounds like an intermittent open in the rotor... I've had an intermittent open like this in a square-back that drove me crazy. It happens. Many of these parts are antiques now.
[Re: Hemi_Joel]
#2932002
06/10/21 02:46 PM
06/10/21 02:46 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I'm going to assume it is a original single field alternator that should charge more than 12.8 volts when you turn the key on and the motor is running. What is the output voltage on the charging wire going back to the battery when it is charging?\ What voltage and amps does it put out on a test stand?" I would look closely at the voltage regulator and its ground next
[Re: Hemi_Joel]
#2932181
06/11/21 03:30 AM
06/11/21 03:30 AM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
What about if the problem is at bulkhead black wire getting into the cab? Alternator can be working but just power going anywhere, so no reading.
