Ignition Lock #2931713
06/09/21 05:05 PM
06/09/21 05:05 PM
Colorado
denfireguy Offline OP
Colorado
I posted once before on replacement locks I just had the keys to my Cuda stolen in a breakin. I immediately ordered a new lock set from one of the restoration companies. Just for grins, I tried the existing key similar to the stolen key in the locks. It did not work in the door locks but it immediately opened the steering wheel ignition lock. I also tried two other old Mopar keys and they opened the ignition too.
Does anyone make a more secure ignition lock? Seems like just about any key that fits in the slot will open the lock. The locks made by Standard available at Oreilly's are just as bad.
Picture is the new cylinder and some of the keys that open it.
Craig
Keys
Re: Ignition Lock [Re: denfireguy] #2931733
06/09/21 06:21 PM
06/09/21 06:21 PM
New Jersey
P
Powerflow Online content
Powerflow  Online Content
P
New Jersey
Your ignition lock may not have all its pins which makes it easier for multiple keys to open it.
Re: Ignition Lock [Re: Powerflow] #2931770
06/09/21 08:13 PM
06/09/21 08:13 PM
IMGTX Offline
IMGTX  Offline
What he said. Sounds like you need a new lock cylinder or the column is broke.
I do not know of a more secure lock but get a club or removable steering wheel with a lock plate. The goal being to make it more difficult to steal. They also have these things that car called steering column lock. Covers the lock and wraps around the column.
Re: Ignition Lock [Re: IMGTX] #2931774
06/09/21 08:21 PM
06/09/21 08:21 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Take the lock to a locksmith and tell him you want all 5 tumblers. Most likely there is only 1 or two in there.
Re: Ignition Lock [Re: NITROUSN] #2931815
06/09/21 10:17 PM
06/09/21 10:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree beer
