Re: Daily driver w/carb misses at 30-35 mph
[Re: topside]
#2932398
06/12/21 01:25 AM
06/12/21 01:25 AM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
OK, so if I'm reading & understanding correctly: Happens at a light decelleration, butterflies partially/mostly closed. At that point, should have a pretty high vacuum reading, not pulling much fuel, no load. Maybe it's a bit too lean @ cruise, or maybe advance weights are sticking (not sure what ignition you have). When you say "missing", does it feel like chugging, or dropping the occasional spark, or like a burble from the exhaust ? Happens when I pull back very slightly on the accelerator due to going down a very slight downgrade. I just pull back ever so slight on the pedal. I'm only pulling back about 5-10%. Seems like it's loosing spark. The first time it did it I thought I was running out of gas for a second.
[Re: VITC_GTX]
#2932435
06/12/21 09:51 AM
06/12/21 09:51 AM
Posts: 16,820 Between Houston & Galveston TX
SattyNoCar
Here's my WAG...... How old is the timing chain? In my mind, I'm picturing when the engine is under load, you've taken up the slack in the chain, but when you 'let up' you're into the slack for a moment. I had a 360 years ago with high miles on its original chain set, and it had several hesitation/stumble issues that went away with a new chain.
John
[Re: VITC_GTX]
#2932729
06/13/21 09:27 AM
06/13/21 09:27 AM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
My daily driver (’57 BelAir 2dr hardtop). ... even though the carb was having issues, choke didn’t work well and was frequently idling high, accelerator pump didn’t work so it had a hesitation from a stop... I finally took the time to replace the carb with an Edelbrock 1403 (500 CFM with electric choke).
With the old carb the car would slightly miss at about 40-45 but you could barely feel it.
I’ve replaced the plugs..
This could have been an issue before I changed carbs as the last carb had issues that may have been masking other issues.
Thoughts on where to start? How confident are you the old and new carbs are set up correctly? .. if you aren't confident, I'm tempted to suspect the carbs.. Can you repeat the problem with the car sitting in your driveway and you manipulate the throttle? If you can, watch the carb throats and see what the fuel is doing.. Flooding or leaning out? Or do you HAVE to be on the road.. ? - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#2933390
06/14/21 10:36 PM
06/14/21 10:36 PM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
lLol. Not laughing at you but with you. Had the Cyclone's engine rebuilt and bought a really nice Quickfuel carb. Nope, that seemed to just go dead at about 2500rpm. Installed a dyno mule Holley that we knew was right, boom, same freaking thing. Finally went with a Holley Sniper EFI system and that took care of the problem. Where was the problem? Not a clue as we replaced the billet distributor, AL box, coil, etc all with Holley gear. Cost plenty to finally get the car running right. Hate to say it but carbs are going to be a thing of the past. Why? Fewer and fewer folks know much about them. Seems like only yesterday that I bought the barracuda and Bee but coming up on 20 years now. I'm will to wager the number of folks that understand(I do) carbs and can fix them(not me apparently) has taken a 50% drop in that time.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
