Aluminum Heads - Does anyone sell a true ready to run?
#2931391
06/08/21 06:16 PM
06/08/21 06:16 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I am considering investing in some aluminum heads. The cost to rework the 452 or 906 heads I have may be better put towards a set of aluminum.
But, does anyone sell a ready to bolt on a go aluminum head? I know several sell complete heads, but I have seen many posts about having to have them torn apart and checked, or reworked before they can actually be used.
I know Edelbrock, 440source, and one other company (the name escapes me) sell complete heads, I just want to be sure I spend wisely if I go that route.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Aluminum Heads - Does anyone sell a true ready to run?
[Re: hp383]
#2931393
06/08/21 06:32 PM
06/08/21 06:32 PM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
10’s of thousands of heads are pulled out of the box every year and ran, mostly with good results. Would I do it?? ? Heck no but then again I can check my own stuff. I had a buddies set of ProMax small block heads partially apart and was impressed enough to call him and talk to him. They are bought as rare as possible and done in-house but then again this was 4-5 years ago. The valve jobs and guilds were beautiful on these heads but I didn’t check every hole as it was a freebe job. TrickFlow stuff is very nice too but someone on this site just found a crack
[Re: merpar]
#2931410
06/08/21 07:26 PM
06/08/21 07:26 PM
Posts: 4,665 Wichita
GY3
Wichita
Without a doubt, Trick Flow heads. If someone claims a crack in a trick flow head I would want to see evidence. I hate hearsay. For street use the 240 are great already CNC ported and ready to run. Pictures were posted.
[Re: topside]
#2931474
06/08/21 10:10 PM
06/08/21 10:10 PM
Posts: 11,707 Portage,michigan
B3422W5
Portage,michigan
Dwayne has told me before he would have no issues running Trick flow stuff. Guides tend to be a hair snug, but well within spec. Ready to bolt on out of the box...
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: LA360]
#2931484
06/08/21 10:31 PM
06/08/21 10:31 PM
Posts: 2,255 IL
furious70
IL
bigger question is can you find anything that you can actually buy right now!
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: DusterKid]
#2931535
06/09/21 08:44 AM
06/09/21 08:44 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I sent a pair of Trick Flow 240’s to Dwayne to check out and inspect.....he said they were good to go the way they were. Guides were right on. Springs, retainers and locks...high quality. They are running as expected.....very well.
I have also run RPMs since 2004 and changed springs to suit my cams, and they are still running great till this day.
And, i have a set of 440 Source non-cnc ported heads that i changed out all the hardware and springs for an upgrade. Those are home ported and also run great.
[Re: topside]
#2931538
06/09/21 08:53 AM
06/09/21 08:53 AM
Posts: 10,702 North Dakota
6PakBee
North Dakota
I'm not sure anyone makes a major component that I would just bolt on & go. Anything worth doing is worth checking over and making sure it's right. This man gets it.
[Re: hp383]
#2931555
06/09/21 09:55 AM
06/09/21 09:55 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
I thought the Edelbrock Victor JR 426 Hemi heads were pretty nice. Stem to guide clearance seemed a little loose which I guess I'd prefer to too tight.
The only thing I didn't care for was a few of the spark plug holes were tapped a little bit roughly. A few plug changes will naturally chase the threads so it is no big deal, but it seemed almost like the machine was running too fast, the tap needed to be replaced, or something like that. But no big deal.
They're for a different engine and nobody has them in stock anyway, so I'll crawl back under my rock.
Rich H.
Esse Quam Videri
[Re: hp383]
#2931737
06/09/21 06:31 PM
06/09/21 06:31 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Here’s a little perspective.......
Think of all the aftermarket heads GMPP sells.
Think of all the crate engines GMPP sells.
Do you think they have a team of people “going through” their head assemblies before installing them on those crate engines? And many of those crate engines are sealed engines for use in various oval track series.
Right out of the crate and into the race car.
There are several series in this area that use them. It’s pretty rare for them to ever have a problem with a cylinder head that isn’t owner induced(severely overheated).
It’s one thing to have the heads gone thru if you looking for a little more performance, and some modifications will be performed.
And you may even find a little thing or two you don’t love......... but it’s pretty rare to find something that would actually cause a “problem”. Generally, if the spring package installed on whatever heads you’re looking at is suitable for the cam you’ll be using........it’s not crazy to use them ootb.
Through the years, I’ve seen the occasional “prepped” heads where I felt like they were likely better before the “prep”.
The fact is, not all machine shops produce top quality work....... that’s just the way it is. So, depending on where you’re having the work done........ they may end up better than ootb....... then again, maybe they won’t.
[Re: fast68plymouth]
#2931757
06/09/21 07:28 PM
06/09/21 07:28 PM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
But yet it happens. Do ya feel lucky? Well do yaaaaa.
[Re: pittsburghracer]
#2931781
06/09/21 08:31 PM
06/09/21 08:31 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
A man's got to know his limitations.
