Re: Picture Thread - Track Racing Mopars!
[Re: MoparMike23]
#2930850
06/07/21 12:03 PM
06/07/21 12:03 PM
Posts: 355 Sparks, Nevada
MoparMike23
Sparks, Nevada
More pics from Thunder Hill
1969 Superbee 440-6 1977 D-150 Adventurer 2000 Jeep TJ 2018 Challenger Scat Pack Shaker 2019 Ram 2500 CTD
[Re: MoparMike23]
#2930852
06/07/21 12:04 PM
06/07/21 12:04 PM
MoparMike23
Sparks, Nevada
Last set of pictures from Thunder Hill
[Re: MoparMike23]
#2930938
06/07/21 03:34 PM
06/07/21 03:34 PM
Posts: 22,695 Bitopia
jcc
Bitopia
That chassis set with the enclosed pics and estimated speeds, looks to be a very well sorted out package. Car to share any of your set-up specs?
[Re: MoparMike23]
#2930989
06/07/21 05:12 PM
06/07/21 05:12 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
Careful, your face may freeze with that smile on it. Looks like it handles pretty well. What size rear tire are you running?
[Re: jcc]
#2930998
06/07/21 05:51 PM
06/07/21 05:51 PM
MoparMike23
Sparks, Nevada
That chassis set with the enclosed pics and estimated speeds, looks to be a very well sorted out package. Car to share any of your set-up specs? Setup is pretty simple and cheap. Stock front suspension with Hotchkis 1.1 torsions and a Summit brand 1 1/8 sway bar. I did get a proper alignment with -1.0 Camber / 3.5 Caster / and toe'd in just a bit. Rear is HD springs, 1.0" blocks, and a 7/8" Summit rear sway set in the middle. I did swap to disc's in the front with EBC Yellows, but the rear still has the 11" drums. Added brake cooling too. The ride height is down from stock but I don't remeber the exact drop. Its super predictable and well manered.
[Re: gzig5]
#2930999
06/07/21 05:53 PM
06/07/21 05:53 PM
MoparMike23
Sparks, Nevada
Careful, your face may freeze with that smile on it. Looks like it handles pretty well. What size rear tire are you running? Here's my tire wheel setup Front Rim: 15x8, 4.5 bs Front Tire: 245/60R15 Rear Rim: 15x10, 5.5 bs Rear Tire: 295/50R15 These tires are roughly 26.5 in diameter front and rear for balance. I studied tire sizes over and over again and compromised with this setup to be safe. The tires are Mickey Thompson's Sportsman S/T's which have a treadwear rating of 440. .......And Yes, I'm still smiling
[Re: MoparMike23]
#2931047
06/07/21 07:40 PM
06/07/21 07:40 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Gotta love the bowtie having a view of your tail lights.
Carl Kessel
[Re: MoparMike23]
#2931113
06/07/21 10:45 PM
06/07/21 10:45 PM
jcc
Bitopia
That chassis set with the enclosed pics and estimated speeds, looks to be a very well sorted out package. Car to share any of your set-up specs? Setup is pretty simple and cheap. Stock front suspension with Hotchkis 1.1 torsions and a Summit brand 1 1/8 sway bar. I did get a proper alignment with -1.0 Camber / 3.5 Caster / and toe'd in just a bit. Rear is HD springs, 1.0" blocks, and a 3/4" Summit rear sway set in the middle. I did swap to disc's in the front with EBC Yellows, but the rear still has the 11" drums. Added brake cooling too. The ride height is down from stock but I don't remeber the exact drop. Its super predictable and well manered. Well that is as well balanced as the car looks. Might as well ask what your drive train is.
[Re: jcc]
#2931133
06/07/21 11:43 PM
06/07/21 11:43 PM
MoparMike23
Sparks, Nevada
Thanks, It really is a happy car. Nice thing is the car can go back to stock if I ever want to go back down that road. Motor is a low compression 440 with a 6 pack. No bogging in the corners. 727 trans that unfortunately gets hot on very hot days but I’m working that out. 8 3/4 rear with 3:23’s. Typically gets into the mid 4K RPMs in the main straight. Best part of the car....still has the bench seat and factory seat belts.
[Re: MoparMike23]
#2932235
06/11/21 10:45 AM
06/11/21 10:45 AM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Last set of pictures from Thunder Hill Thanks, It really is a happy car. Nice thing is the car can go back to stock if I ever want to go back down that road. Motor is a low compression 440 with a 6 pack. No bogging in the corners. 727 trans that unfortunately gets hot on very hot days but I’m working that out. 8 3/4 rear with 3:23’s. Typically gets into the mid 4K RPMs in the main straight. Best part of the car....still has the bench seat and factory seat belts. Man, how fun.. That shot of you with oversteer looks like a blast.. ! - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: MoparMike23]
#2933219
06/14/21 02:03 PM
06/14/21 02:03 PM
Posts: 1,440 NW Chicago suburban area
Mopar Mitch
Nice pics... lots of fun!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
