HELP!!! Axle end play over .100 #2930405
06/05/21 09:37 PM
06/05/21 09:37 PM
Oklahoma City, Oklahoma
MrMayhem Offline OP
MrMayhem  Offline OP
Hey guys,
I just swapped out my old 741 center for a rebuilt one both are clutch type limited slips units with 3.91 gears. Prior to disassembly the axles end play checked good, with the new 741 in place both left and right axles have a ton of end play. I tried to adjust it out but no prevail.
I need this back on the road asap.... What am I doing wrong?
Re: HELP!!! Axle end play over .100 [Re: MrMayhem] #2930408
06/05/21 09:46 PM
06/05/21 09:46 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Are the thrust buttons still in place? Sometimes the roll pin will break.
Re: HELP!!! Axle end play over .100 [Re: mopars4ever] #2930411
06/05/21 09:59 PM
06/05/21 09:59 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
if its an aftermarket sure grip they have a much smaller thrust spacer for some reason...my 3:73 i picked up would not adjust same as yours... just reinstalled my old 3:55 and its fine.. its 100% thrust spacer related ..good luck
Re: HELP!!! Axle end play over .100 [Re: mopars4ever] #2930412
06/05/21 10:02 PM
06/05/21 10:02 PM
MrMayhem Offline OP
MrMayhem  Offline OP
I am not certain if the spacers are still there, didnt even look.... I just assumed it was there.....
If it is not, how much of chore is it to remove from my other diff?
Or is this a good time to upgrade to Green bearings?
Thank you
Re: HELP!!! Axle end play over .100 [Re: MrMayhem] #2930430
06/06/21 01:55 AM
06/06/21 01:55 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Personally I'd put green bearings on it and call it a day.
Re: HELP!!! Axle end play over .100 [Re: slantzilla] #2930466
06/06/21 10:56 AM
06/06/21 10:56 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
As much as I am an opponent of the green bearings, You said you needed it done ASAP. I would agree it is the quickest solution. Especially with PH23VO's comment.
And PLEASE let's not get the bearing debate going AGAIN twocents beer
Re: HELP!!! Axle end play over .100 [Re: MrMayhem] #2930475
06/06/21 11:30 AM
06/06/21 11:30 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If the buttons are not in, removing the center again to install them is a lot easier and cheaper that buying and pressing on new bearings.
Faster too.
Re: HELP!!! Axle end play over .100 [Re: Alaskan_TA] #2930601
06/06/21 08:07 PM
06/06/21 08:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Faster too.
I'd agree wink
But per ph23vo
Quote
I have encountered a few, new aftermarket 10/12 bolt GM differentials that the C-clips for the axle retention wouldn't fit. So it may depend on what he's dealing with shruggy beer
Re: HELP!!! Axle end play over .100 [Re: TJP] #2930894
06/07/21 01:35 PM
06/07/21 01:35 PM
MrMayhem Offline OP
MrMayhem  Offline OP
I just wanted to say thank you all for the insight.... the diff I installed did not have the thrust buttons installed. I did remove the button from the old diff and problem solved! That being said..... I will hold off for the moment on a bearing change but I did opt to order 3 inch studs, my Weld draglites do not like the short studs even with the weld racing lugs and proper torque sequencing I tend to tweak the studs pretty frequently. Tired of cutting off lug nuts.
Re: HELP!!! Axle end play over .100 [Re: MrMayhem] #2931069
06/07/21 08:34 PM
06/07/21 08:34 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
thanks for the update and glad you resolved the issue beer
Re: HELP!!! Axle end play over .100 [Re: Alaskan_TA] #2931071
06/07/21 08:35 PM
06/07/21 08:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
spank
Faster too.
OK I'll take my beating now LOL spank beer
