Water line easement??? #2929811
06/03/21 04:11 PM
06/03/21 04:11 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Anyone familiar with granting easements? I have 25 acres of land and a private water company wants to run a pipe through it to get water to an area of the valley that can't get water in their wells, what is fair to ask in return for granting them permission? I have a well at my house on the 20 acres so I don't really need a hook up there, I am building a spec house on the 5 acres and am planning to put in a well (about $10,000), they are trying to talk me into hooking it up to their water system but are asking about $30,000 (that's more than I paid for the 5 acres). Their proposed route goes through both pieces of my land, they could avoid the 5 acres pretty easy but it would be hard to avoid the 20. I don't want to be a jerk but also don't want to give up an easement for the rest of time for nothing when I may someday want to do something in that part of the land...
Re: Water line easement??? [Re: HotRodDave] #2929815
06/03/21 04:31 PM
06/03/21 04:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Above ground or underground ? Straight through, or can it be routed so you could subdivide your land later ?
And, to clarify, they offered $30K TO you, not FROM you ?
And what are they feeding, a few homes, subdivision, farm, industrial...?
You might consider a monthly or yearly fee for compensation on top of an initial fee, for several reasons.
Not the least of which is to remain on the books and to address risk, usage, maintenance, and inflation.
Re: Water line easement??? [Re: topside] #2929819
06/03/21 04:50 PM
06/03/21 04:50 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Take a look at how wind turbine rights are done. Generally, there is a charge for the physical aspect, the installation, then access rights per year, some even get a percentage of the money from the power generation. If they want to charge you $30k to hook up to their water you can bet your price shouldn't be less than that.
Re: Water line easement??? [Re: Sniper] #2929823
06/03/21 04:55 PM
06/03/21 04:55 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
cell towers are kinda the same around here. if you put one on the guys property, he gets $ up front,$ every month and what ever else he can get out of their azz. DON'T GIVE IT AWAY.
Re: Water line easement??? [Re: topside] #2929831
06/03/21 05:10 PM
06/03/21 05:10 PM
Kalispell Mt.
Kalispell Mt.
They want me to pay $30,000 if I hook up the house I am building to flip. If they had offered me $30,000 in cash I would have probably said show me the money! That is a separate issue from anything I would get in return for them running the pipe through my land, either one or both lots.
It is a mostly residential area with a couple small businesses, they have been hauling water in around me for years as the well drillers made a habit of drilling past the water seemingly to make more money as they get paid per foot, my well works great at 52 feet while all the 600-900 foot wells around me are dry.
I would think the water line would be underground, it would risk freezing above ground here in the winter.
Re: Water line easement??? [Re: HotRodDave] #2929833
06/03/21 05:23 PM
06/03/21 05:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds to me like they are trying to work a deal where you allow the pipe line and they hook up the new house for free. Not a good deal considering you have well water available.
Re: Water line easement??? [Re: HotRodDave] #2929838
06/03/21 05:39 PM
06/03/21 05:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Well, they have some nerve proposing to charge you when they're hoping to run pipe through your land. Hardly an incentive !
If you can contact whoever's hauling the water and find out what they're charging, that would help your figuring.
Seems to me your fee needs to cover land value, loss of use of the land their pipe & whatever will occupy, and whatever interference results from maintenance.
Getting a piece of the action on top of that wouldn't be unfair, and keeps you in the info & consideration loops.
I'd start with either free water, or enough for you to do your own 2nd well (probably the simpler & better option).
You might want to do some research on "eminent domain", "land rights", etc on Wikipedia.
Also, if you enter into a contract or agreement, if there's an attorney near you who's good with land use, rights, etc, I'd consult with him/her as a CYA.
Re: Water line easement??? [Re: topside] #2929843
06/03/21 06:07 PM
06/03/21 06:07 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Just no. My friend's neighbor just got $47,000 for a pipeline to go through the corner of their land. Additionally she got $1000s a tree they took down on the fenceline. This isn't a temporary deal this goes to the new owner of the house.
Re: Water line easement??? [Re: moparpollack] #2929867
06/03/21 07:56 PM
06/03/21 07:56 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Unless ou are handsomely compensated, it is truly not worth the hassle in my opinion.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Water line easement??? [Re: BloFish] #2929943
06/03/21 11:34 PM
06/03/21 11:34 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
^^^^THAT, and how much much to have a private well drilled? The thing is this: If they're allowed to run that pipe, YOU are restricted from doing whatever you want on "your" own property. There's a bunch to be put into perspective before you sign on a dotted line. Personally, I'd talk to a GOOD real estate laywer.
Re: Water line easement??? [Re: HotRodDave] #2929948
06/03/21 11:48 PM
06/03/21 11:48 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
I would not do this. The nerve of charging you 30gs makes me think they won't be very good if a leak happens. The lay of your land (and the adjacent parcels) will be a major factor compounding the water damage.
This happened awhile back and is still ongoing:
https://nbc16.com/news/local/landsl...uary-could-cost-school-636000-04-19-2021
The soil here is full of clay and the slope of the bedrock is a nightmare for mitigating structural damage, cause once it starts, no telling how it will stop.
btw
Don't even think of getting help from property insurance. That is classified as "movement of the earth" and is not covered by any policy I'm aware of.
Re: Water line easement??? [Re: A990] #2929951
06/04/21 12:11 AM
06/04/21 12:11 AM
5thAve Offline
5thAve  Offline
They want to run through your property and then have the nerve to want to charge you 30k to hook up? Talk about kick in the ass.
What issues are you going to have if their pipe leaks and causes some sort of sink hole or major damage to your property? What trouble are they going to cause you if something damages the pipe and they blame it on you? What kind of mess are they going to make digging up the pipeline in the future if it needs maintenance? How's it going to affect your land value?
I'd find a lawyer that is familiar with this sort of situation and talk to them.
Re: Water line easement??? [Re: HotRodDave] #2929953
06/04/21 12:17 AM
06/04/21 12:17 AM
AndyF Offline
AndyF  Offline
Tell them they can put it on the fence line in exchange for the hookup to your house. I wouldn't allow them to put it across the land unless it was really buried deep.
Re: Water line easement??? [Re: AndyF] #2930045
06/04/21 02:10 PM
06/04/21 02:10 PM
Addison Twp, Mi.
RobG Offline
RobG  Offline
Addison Twp, Mi.
As Nancy Reagan once said, "Just say NO!"
We have an easement on the farm and it is a huge mess. The utility is to contact us up to 2 weeks prior to having crews do maintenance /inspections. They never do and they always drive out of the easement area. They hauled ass through my deer food plot and tore that entire area up.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: Water line easement??? [Re: HotRodDave] #2930229
06/05/21 09:51 AM
06/05/21 09:51 AM
Massachusetts
Faust Offline
Faust  Offline
Massachusetts
Easements have a way of coming back to haunt you. Prior owners had given a power company a "lease" (very unusual, and not well described in the paperwork) about 100 years ago to run transmission poles across the property. Those poles were removed in the 1950's. The "lease" made the property unsaleable (no one wanted a hassle with the power company). Fortunately, the power company agreed to comply with the law in exchange for $5,000 for "documentation costs". The law was unquestionably on my side. Could have been much worse, so I was glad to pay it.
Will the water line benefit you in any way?
Re: Water line easement??? [Re: RobG] #2930244
06/05/21 11:00 AM
06/05/21 11:00 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
There ya go.
As Nancy Reagan once said, "Just say NO!" NO NO NO AND A BIG NO.
STOP POTATO HATE!
Re: Water line easement??? [Re: RobG] #2930278
06/05/21 01:30 PM
06/05/21 01:30 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Sounds like the agreement was poorly written or poorly enforced. around here that would be a fineable offense with restitution included. When I worked the oil patch all that was spelled out in the agreement. Might be smart to get a lawyer to at least review the agreement before signing on.
Re: Water line easement??? [Re: Faust] #2930291
06/05/21 02:23 PM
06/05/21 02:23 PM
Kalispell Mt.
Kalispell Mt.
Only way I see it benefiting me directly is if my well ever dries up and I am forced to start buying water from him. Also indirectly it is a little more complicated than just saying "NO", I have several close friends who will be tapping into it, don't want to cost my friends a bunch of money or stop their water project all together.
Re: Water line easement??? [Re: HotRodDave] #2930365
06/05/21 07:50 PM
06/05/21 07:50 PM
5thAve Offline
5thAve  Offline
It sounds like you want to go ahead with it in some form so like I said in another reply get a lawyer involved to make sure you're not screwing yourself.
Re: Water line easement??? [Re: 5thAve] #2930470
06/06/21 11:16 AM
06/06/21 11:16 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Exactly. Let them hand you their proposed agreement, and have your lawyer "fix it." Believe me, their legal counsel doesn't have your best interest in mind. As a part of that, get your stub outs installed so you can easily tap in at a later date, if you wish to.
